  • Replies 242
  • Created
  • Last Reply
Top Posters In This Topic
Might wanna put and explain lockouts, stiffer springs, and maybe an override is recommended and why. Would help newer guys understand. That way they dont buy a $1500 set up and cant afford to make it work well.
You may be right but,
I think that's what the forums are for.
I had this thought ... it's recomended to run a pancake bearing & maybe a nice ball bearing clutch perch with a high performance clutch too, where does liability for advertising stop ?
Edited by Forcefed
190 Ex - 128 Main transfer with ports cracked as shown - should be a way fun ride.
6858 with .020 base.
0.0 - .002 positive deck
Base nut area needed a touch of clearancing.
Ignore the lint :)
Edited by Forcefed
No grinding what so ever.
Installed as received.
According to spec a .012 base is suppose to have the piston in the hole .005 also ... however with a .020 gasket, the deck is 0 to .002 positive.
I don't have the blueprint in front of me but I did set mine up just like a 68x58 cub which was .012 gasket .01 in the hole. I used .03 step in the dome put me at .04-.045 total squish.
What's the rest of your setup going to be? If you need anything else to finish her up just let me know.
Hmmm... wonder where the descrepancy is ?
I also left the flashing in the ports as finished by Millenium.
The rest of the set-up ...
Checking out a Noss head for the 1st time.
Will confirm dome profile when they arrive.
Pump gas
CPI SB Inframes / FMF Fatty's
35 PWK's
V-Force 3's
K&N in the box / Pods
DriveLine Clutch Drag version w/pancake
Adj. Timing plate
Will probably start at 0 on the plate with the FMF's & filter in the box.
160 mains & 50 pilots DEK needle in the middle. 900ft 70* Low Humidity
Thanks for the offer, it's appreciated.
To respond to a couple PM's.
Head by Noss - dome profiling by Titan.
No lid on the box.
91-93 octane is available & will be used.
Matched reed stuffers to intake.
Cases unported/matched for now.
Has your cases been decked? What crank are you running?
Cases are virgin.
Hotrods crank.
58 Stroke
115 Rod
573 Wiseco Piston
Edited by Forcefed
