  • Replies 242
  • Created
  • Last Reply
Top Posters In This Topic
Post some good pics of the ports man
Why? To the naked eye...you'll barely be able to tell the difference between it and a cub, unless you've never seen the porting on a cub before.
The port timings are different by a couple mm's. That's hard to see by the naked eye...
No worries. Yeah I know the port timings are lower then the cubs. Since I first heard about these things I have been trying to get as much info as I can. I want to see if any builders do any testing on them. I know everyone is saying to not port them because then you might as well go with a cub. But, you can see there is a big difference in the curve between these and the cubs. So if someone could get some extra power out of them but keep the power curve it would be killer.
I know I'm asking for a lot but I would like close to stock cub numbers but a broader powerband without having to spend the money on a cheetah. Right now I think these Servals are only making about 5-10 more hp then my 4mil setup but they have a much smoother power delivery.
My advice would be to run them as cast, except cleaning up the flaws.
If you try to get more power out of them not only should you buy a cub, but...you'll have a cub type power delivery which is exactly what you don't want from a set of these.
I wish I had a duner...lol.
Where's a link to tell the prices of everything needed to make this work.
I'm debating trying this because i already have a 4mil longrod crank. I'm afraid the power wont be as smooth as my current set up.
That's $200 for the pistons, $700 for the cylinders and heads/domes/stub extenders?
