bansheeboi Posted September 7, 2010 Report Share Posted September 7, 2010 yall im trying to tear my motor down and the flywheel wont come off i order a brand new flywheel puller sprayed wd-40 in there to get lossen and man that damn thing still wont come off so anyone have any ideas on what to do next it getting cold so im starting my rebuild now be done before the new year Quote Link to comment Share on other sites More sharing options...
brugal Posted September 7, 2010 Report Share Posted September 7, 2010 Put the puller on there good and tight ,then hit the end of the puller with a hammer. It'll pop write off. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted September 7, 2010 Report Share Posted September 7, 2010 1/2" impact set full out and zip-zap it off in 1 second or your money back guarantee. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted September 8, 2010 Report Share Posted September 8, 2010 1/2" impact set full out and zip-zap it off in 1 second or your money back guarantee. depends on the impact....i guarantee a thunder-gun would rip it to shreds. i say between 200-300 ft/lbs and smack it. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted September 8, 2010 Report Share Posted September 8, 2010 ahh the thunder-gun......nothin says you value your tools more than a impact that's able to bend metal....break welds...or absolutely fuck up the part you were trying to remove the bolt from....BAHAHAHA. no seriously though....the thunder-gun aint nothing to laugh at.....DAMN strong! and like said......put a good crank on the flywheeler puller and hit the end of the puller with a hammer......if that still doesn't work try this.....this takes longer but works the same.... step 1......put puller on step 2.....crank puller on pretty damn tight (use common sense here....don't put a freakin 8 ft breaker bar on it...) step 3.....go inside and grab a beer step 4.....check on it in AM and it should have popped off from the force being applied all night... Quote Link to comment Share on other sites More sharing options...
