coreyownz Posted September 4, 2010 Report Share Posted September 4, 2010 changed the oil yesterday in my banshee cause itd had some use. so change it checked it all was good. went to go riding today and i can go 1st second than to try and get into third is impossible i have to pull the shifter up like 2inches farther than normal and when i checked my oil it was empty. theirs no leaks that i can see could this be the crank seal? thanks Quote Link to comment Share on other sites More sharing options...
EvilBanshee Posted September 4, 2010 Report Share Posted September 4, 2010 What kind of oil did you use?? Maby try putting in some thicker oil like 80-90w gear oil. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted September 5, 2010 Report Share Posted September 5, 2010 What kind of oil did you use?? Maby try putting in some thicker oil like 80-90w gear oil. Yea 80w-90 is not a good idea. It is a hypoid gear oil made for differentials. Most of them contian really high amounts (more than standard automotive engine oil) of Molybdenum wich will cause a wet clutch to slip. Once the clutch is contaminated you have to thow it away. Quote Link to comment Share on other sites More sharing options...
coreyownz Posted September 5, 2010 Author Report Share Posted September 5, 2010 im more worried about the not shifting Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted September 5, 2010 Report Share Posted September 5, 2010 im more worried about the not shifting Yea, but if you use the 90 weight you will be worried about the not shifting AND the slipping clutch. I would pop the clutch cover off and look at the shift mechanism to see if anything is loose or has come off. Also, check the adjustment of the shift shaft eccentric, and make sure the hooks on the shift shaft aren't sloppy, they should be centered over the pins on the shift star. Quote Link to comment Share on other sites More sharing options...
coreyownz Posted September 5, 2010 Author Report Share Posted September 5, 2010 i got the cover off but im not sure what im looking at. i see below the clutch to the left is what moves when i shift but how do i tell if somethings out of adjustment? Quote Link to comment Share on other sites More sharing options...
coreyownz Posted September 6, 2010 Author Report Share Posted September 6, 2010 anyone got pics of what to do? id really appreciate it Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted September 6, 2010 Report Share Posted September 6, 2010 If you have a Clymer's manual, it will tell you exactly what to do, and it also has pics. If you don't have, it's a must have. Quote Link to comment Share on other sites More sharing options...
