Hank Posted September 4, 2010 Report Share Posted September 4, 2010 Looking on the sale forum for some keihin 35 pwk's. I found some Mikuni 34mm and 35mm (round slide). Would the Mikuni's work for my stock stroke cheetah cub set up or am I better off with the keihin's? If the Mikuni's would work, will they use the same jets as the stock carbs and the same throttle cable? If so, what mains would they use? I am currently running 420 mains with the stock carbs. Thanks for the feedback... Quote Link to comment Share on other sites More sharing options...
rdzbangshee Posted September 4, 2010 Report Share Posted September 4, 2010 Looking on the sale forum for some keihin 35 pwk's. I found some Mikuni 34mm and 35mm (round slide). Would the Mikuni's work for my stock stroke cheetah cub set up or am I better off with the keihin's? If the Mikuni's would work, will they use the same jets as the stock carbs and the same throttle cable? If so, what mains would they use? I am currently running 420 mains with the stock carbs. Thanks for the feedback... the cable and jets mite be different . and the keihins are better built and last longer. Quote Link to comment Share on other sites More sharing options...
Hank Posted September 4, 2010 Author Report Share Posted September 4, 2010 So I am better off with a Keihin 35 pwk then. Is the keihin 34 mm an older version? Any recommendations for the needle and jetting for Florida? Thanks for the info... Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted September 5, 2010 Report Share Posted September 5, 2010 So I am better off with a Keihin 35 pwk then. Is the keihin 34 mm an older version? Any recommendations for the needle and jetting for Florida? Thanks for the info... Yea the PJ34mm is an older design carb. You want a PWK carb. Quote Link to comment Share on other sites More sharing options...
