Can a lockup be powder coated?
SandShots
I wouldnt do it. I would think the pc would make it stiff and less effective.
If you want a colored lockup just find some one who does Anodizing. There are lots of people who do custom andodizing for Paint Ball Markers.
i havent found anyone yet that will do it, all the shops around here are only willing to do large quantities at once. i guess my 3 items i have isnt worth my business, still looking around.
any sponsors got a hookup for anodizing?
The sponcers are going to be using a bulk anodizer. Where they have an alotment of parts done at once. That is why I said to look for a custom paint ball maker anodizer. You will need to tear it down so your just sending in the aluminum body
http://gruntbullanodizing.com/index.html
http://fbmfactory.com/fbmf/anodizing.html
http://www.kohnsports.com/kohnlasering/anodizing.php
http://aplusanodizing.com/
http://www.doropaintball.com/Anodizing.asp
Anodizing is usually done by the batch. Usually they dip a basket full of parts. It more or less gets priced by the basket load. They only want to do things in bulk. A paintball shop is a great idea. Piggyback on their order and I bet it will be cheap!!
maybe diamond dize it. that stuff is amazing. you can see it on youtube. i did my pressure plate instead, with engine enamel. no flaking or chipping yet, and if it does, it isn't going to chew up the tranny/gears. if you want to do the lockup in pc, have them mask off the finger channels, mount surfaces, and screw holes
stiff? well i wouldnt do it on the weights or arms that open up, only on the body.
good job man, looks good. i sent the stuff out, gimme about a wk, so i can get it back after the holiday weekend and i'll snap some pix to share .
Every anodizer has a "minimum" charge. They'll do any quantity you want, but they won't give you a discount for a single part. I anodized mine and the clearances were fine. However, if you PC it, I doubt the arm to body clearance will be ok. If you DO PC it, ask the PC'er to tape off the sections that are tolerance specific.
