couple questions
i did buy the clymers manunal but just want to ask a cupple questions
with this dome does it need a o ring or something on it
http://img832.imageshack.us/i/dsc02140h.jpg/
this is the stock dome. i live in new york what a good size cc its dosent have alot mods its has like bassic exhaust intake headers jetted and a bit more
http://img836.imageshack.us/i/dsc02141y.jpg/
how do you remove this i gues it would be the flywheele i not sure do you have to remove both bolts like i pointed out in the picture
http://img715.imageshack.us/i/dsc02138b.jpg/
http://img828.imageshack.us/i/dsc02139g.jpg/
thanks guy for all your help
that is a stock head use the factory gaskets
the second to last pic is the flywheel you need to take the nut of in the center then use a puller made for a banshee to pull it off dont pry and use a hammer or the wrong puller,or you will damage the flywheel.
the last pic is the clutch you need to remove the 6 bolts in the circle with the spings under the not the center one, then under the stuff that comes out there is one big nut you take off to remove the rest of the clutch.
Edited by toytech
ya i dont have a flywheeler puller i gues without that i screwed
take it to a local yamaha dealer they can pull it off for $5 or so,or order a puller site sponsors have them for about $15 to $20 then you'll have one
