09Shee09 Posted August 28, 2010 Report Posted August 28, 2010 (edited) Hi, I need to know What main jet size Should I Use My Mods : T-5 Pips K&n Pods and every Thing is stock I Drive in middle East .. Exactly in Qatar .. the elevation is 6.6ft I dont Know My premix ratio but I mix 20 L of 93 oct fuel With 1/2 L of maxima castor oil I havent Change Any thing in the carbs until now just the main jets and they are 260 now What is needle setting and were is the pilot jet located ? Sorry For asking too Much because I am Banshee Newbie Edited August 28, 2010 by 09Shee09 Quote
CarvedArt Posted August 28, 2010 Report Posted August 28, 2010 Hi, I need to know What main jet size Should I Use My Mods : T-5 Pips K&n Pods and every Thing is stock I Drive in middle East .. Exactly in Qatar .. the elevation is 6.6ft I dont Know My premix ratio but I mix 20 L of 93 oct fuel With 1/2 L of maxima castor oil I havent Change Any thing in the carbs until now just the main jets and they are 260 now What is needle setting and were is the pilot jet located ? Sorry For asking too Much because I am Banshee Newbie Your Ratio is about 40:1 (20 L with .625 L will get you 32:1) I'm not sure what size jets you started with so... T5 Pipes = Starting jet size, plus 7 to 8 sizes larger on the Mains / 0 to 1 size larger on the Pilots (25 or 27.5) / 0 to 1 clip position lower on the needle K&N Pods = Starting jet size, plus 4 to 7 sizes larger on the Mains / 0 to 1 size larger on the Pilots (25 or 27.5) Stock Pilot size = 25 Stock Needle Jet = 5N7 (3rd-clip) [The Needle Jet has 5 grooves, from the top: 1,2,3,4, and 5] Stock Main Jet = 200, 210, 220, or 240 The Pilot Jet is located inside the fuel bowl, inside of the small tube that runs parallel to the Main Jet, under the little plastic splash shield that slides over the Main Jet. My guess would be 27.5 Pilot / 4th-clip Needle / about 13 sizes larger on the Main to start. Try this: http://www.4shared.c...al_Toolkit.html download the latest version of the file. (Banshee Digital Toolkit) Quote
sleeper06 Posted August 28, 2010 Report Posted August 28, 2010 300 mains,27.5 pilots,1turn out on screw but adjust for nice idle,needle in the middle till you see how she acts Quote
