AdrenalineJunky Posted August 24, 2010 Report Share Posted August 24, 2010 Closest i've come yet but I lost 1psi in 6 min. Sprayed soapy water everywhere and don't see or hear anything. Is this enough to matter and if so where should I check? Quote Link to comment Share on other sites More sharing options...
hercalmighty Posted August 24, 2010 Report Share Posted August 24, 2010 Check and make sure its not your tester. When I first put mine together I had a little pin hole that I had to seal up. Quote Link to comment Share on other sites More sharing options...
AdrenalineJunky Posted August 24, 2010 Author Report Share Posted August 24, 2010 (edited) I've sprayed it to and don't see anything. Just went and sprayed it again and there is a small bubble coming out of bottom side of gauge side of tester. Does that sound like about a 1psi leak in 6 minutes? LOL Edited August 24, 2010 by AdrenalineJunky Quote Link to comment Share on other sites More sharing options...
hercalmighty Posted August 24, 2010 Report Share Posted August 24, 2010 Thats probably all it is. If you only lost 1psi over 6min your fine Quote Link to comment Share on other sites More sharing options...
shanYE west Posted August 24, 2010 Report Share Posted August 24, 2010 run it... Quote Link to comment Share on other sites More sharing options...
spurdy Posted August 24, 2010 Report Share Posted August 24, 2010 I've sprayed it to and don't see anything. Just went and sprayed it again and there is a small bubble coming out of bottom side of gauge side of tester. Does that sound like about a 1psi leak in 6 minutes? LOL That is probably it. It is likely ok. But, as particular as I am I would glue the hole shut and retest. But I'm an anal bastard when it comes to that shit! Lol! SP Quote Link to comment Share on other sites More sharing options...
AdrenalineJunky Posted August 24, 2010 Author Report Share Posted August 24, 2010 LOL ya I already sealed the hole. Waiting for it to cure and retest lol............I am anal too. I am by the book hehehe. That's why the youth where I work hate me. I work in a Juvenile Correctional Facility and they say i act like I am a secret service agent lmao. Quote Link to comment Share on other sites More sharing options...
AdrenalineJunky Posted August 26, 2010 Author Report Share Posted August 26, 2010 Good to go now I checked about 20 minutes later and it lost about 1psi. Quote Link to comment Share on other sites More sharing options...
Nutwood 472 Posted August 26, 2010 Report Share Posted August 26, 2010 Good to go now I checked about 20 minutes later and it lost about 1psi. did you spray underneath the outter crank bearings,of the bottom case,they can get hair line cracks and they will leak oil out of them,just went through all that hassle and had to seal it up with some epoxy,and ran a couple tanks of gas through it and today I tore the carbs off and pipes and did leak down test to see if the fix was holding,it held it for 45 min or until I let the pressure off,so if your still losing,I would spray down again,a small leak can trun into a bigger one. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted August 26, 2010 Report Share Posted August 26, 2010 run it... X2. Wouldn't hesistate for a second to run it. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted August 27, 2010 Report Share Posted August 27, 2010 I had the same problem and it was my tester. Sealed it up and it held it for over 20min. I'd fine the leak but what do I know. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted August 27, 2010 Report Share Posted August 27, 2010 I dont know if any one asked but did you seal the keyway by the primary drive gear,ive only seen it leak 3 times on teardowns but its still a shot Quote Link to comment Share on other sites More sharing options...
AdrenalineJunky Posted August 28, 2010 Author Report Share Posted August 28, 2010 I thought it was 6psi for 6 minutes? Quote Link to comment Share on other sites More sharing options...
shanYE west Posted August 28, 2010 Report Share Posted August 28, 2010 it doesn't have to be perfect to pass the test.. I usually end up leaking about 1lb in 6min.. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted August 28, 2010 Report Share Posted August 28, 2010 It is 6 psi for six min Quote Link to comment Share on other sites More sharing options...
