stroking Posted August 24, 2010 Report Share Posted August 24, 2010 IS it a must to run a lockup with a override tranny ?? does anyone have a override with a regular clutch setup ? whats the best clutch to use also ? Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted August 24, 2010 Report Share Posted August 24, 2010 it kinda works backwards than that man. you really want to have an override if you have a lockup because its almost impsossible to shift a stock tranny with a lockup. a lockup is needed when you have a badass motor to keep the clutch from slipping. the FAST clutch is about the best clutch ive ever heard of. Quote Link to comment Share on other sites More sharing options...
stroking Posted August 24, 2010 Author Report Share Posted August 24, 2010 i have a override already but i dont want to use a lockup IF i dont have to. its not a big motor, YET! Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted August 27, 2010 Report Share Posted August 27, 2010 Absolutely no problem,I have built three bikes this way its the other way around that gets sticky lock-up no overide Quote Link to comment Share on other sites More sharing options...
oakshee Posted December 30, 2010 Report Share Posted December 30, 2010 its kinda your call on the lock up from the sound of it your into racing...since youve got the override and with out a lock up the clutch will slipp even tho you cant realy feel it or hear it campared to a bike with a lock out..just look at how a lock up works...lik i said its not life thretning with out but there will be slipage Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 30, 2010 Report Share Posted December 30, 2010 Stroking, What is the current size of your motor? You race pavement, right? Why "DON'T" you want to run a lockup? Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted December 30, 2010 Report Share Posted December 30, 2010 its almost impsossible to shift a stock tranny with a lockup. lol, that's not true, I never had any problems shifting a stock transmission while running a lockup. Maybe you have some worn forks or a bent shift shaft. Anything over 75-80 hp, you'll want a lockup I use R1 fibers and raptor steels in my clutch Quote Link to comment Share on other sites More sharing options...
shanYE west Posted December 30, 2010 Report Share Posted December 30, 2010 lol, that's not true, I never had any problems shifting a stock transmission while running a lockup. Maybe you have some worn forks or a bent shift shaft. Anything over 75-80 hp, you'll want a lockup I use R1 fibers and raptor steels in my clutch Same here Travis.. No problems at all with lock up and stock trans. I personally have had good luck with Tusk kits. Usually one a season. But I use toomey springs instead of the Tusk springs. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted December 31, 2010 Report Share Posted December 31, 2010 My override did ok without a lockup. But my worn out clutch slipped. I went with a cheap slingshot lockup so i can run 3HD/3 regular springs. I love an easy clutch pull. Gonna go to a hydraulic set up one of these days. Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted December 31, 2010 Report Share Posted December 31, 2010 why dont you wanna run a lock up? Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted December 31, 2010 Report Share Posted December 31, 2010 No problem shifting a stock style trans with a lockup here... Quote Link to comment Share on other sites More sharing options...
stroking Posted December 31, 2010 Author Report Share Posted December 31, 2010 why dont you wanna run a lock up? its more weight,so if i dont need it i would prefer to not run it. so far its been working good with one,its a stockcylinder/stock stroke drag bike with a n-d 1-5 override. Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted December 31, 2010 Report Share Posted December 31, 2010 I didnt run a lock up on my 4 mill for a while and didnt think the clutch was slipping.... noticed a big difference when I added a lock up though... the added weight is offset by getting more power to the wheels..... Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted January 1, 2011 Report Share Posted January 1, 2011 With a DD style lockup you can really tune your 60ft times,cut springs,take away some weight ,pin it and hold on Quote Link to comment Share on other sites More sharing options...
df350nos Posted January 3, 2011 Report Share Posted January 3, 2011 With a DD style lockup you can really tune your 60ft times,cut springs,take away some weight ,pin it and hold on I run a 4 mil with an overide 1-4 shift 5th and sixth for asphalt . I run sand to and run the crap out of it. The clutch and tranny been together 3 years and it still does not slip. And I have no lockout. Know that motor only making about 72 or 73 hp but still I personally think thats pretty good. Quote Link to comment Share on other sites More sharing options...
