new to me banshee (fuel)
Mix it in your gas can before you put it in the bike. I mix mine at 40:1 because it does an even 10 gallons.
Yes you must PRE MIX the fuel with the oil.......
Everyone runs different ratios.....I run 38:1 or close to it.....40:1 somewhere in that area will be fine
Get high quality synthetic or synthetic blend 2-cycle oil. Not the shit off of Walmart's shelves. Until you know what you're working with, be safe and mix your oil at 32:1 (4ozs/gal)
thanks guys, i just traded my lifted jeep for it and asked every other question except for......... can i run vp race fuel on a next to stock machine? it has fmf fatty pipes boysen reeds, jetting and a slight over bore, not sure what size over bore but im guessing the next size up.
on a almost stock motor running race fuel will actually bring down your preformance. Not sure what you know about fuels so don 't freak out if you already know this.....but higher octane fuel actually has a more controlled SLOWER burn. You don't need to run race fuel unless your compression is really high. and No.....running a high octane fuel does not make your quad run faster. :headbang:
cool, i just thought id ask cuz i have a couple gallons of VP left from my jeep (4.7l stroker) it was high comp running 40. over chev pistons and 2.02 ls1 intake and 1.60 exhaust ls1 valves and ran like shit on pump gas, i am just premixing with premium. maybe next spring ill have a high comp stroker in my banshee, just had it for a couple days and am already wanting more power, not that it doesnt already have some. more is always better.
Edited by Banshee420John
I smell a blown engine!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
