power Posted August 15, 2010 Report Share Posted August 15, 2010 Hey guys. Got a stupid question i guess lol. If i remove the left handle bar switch."plug it out".will the bike start then or do i need to do some mods? Quote Link to comment Share on other sites More sharing options...
12 0 Clock P I M P Posted August 15, 2010 Report Share Posted August 15, 2010 Hey guys. Got a stupid question i guess lol. If i remove the left handle bar switch."plug it out".will the bike start then or do i need to do some mods? It will start the only wires there are the headlight/high/lowbeam wires and a black/white wire for the start stop....you can strip all that shit....if you want a tether switch or something just keep the black/white wire up around there........for later use......its just a ground to kill the engine.....so you can tape it out.....you dont need many wires at all to run the bike.......FYI that black/white runs to cdi box.... Quote Link to comment Share on other sites More sharing options...
power Posted August 15, 2010 Author Report Share Posted August 15, 2010 It will start the only wires there are the headlight/high/lowbeam wires and a black/white wire for the start stop....you can strip all that shit....if you want a tether switch or something just keep the black/white wire up around there........for later use......its just a ground to kill the engine.....so you can tape it out.....you dont need many wires at all to run the bike.......FYI that black/white runs to cdi box.... Ok thanks alot. Then i gonna do that. Quote Link to comment Share on other sites More sharing options...
12 0 Clock P I M P Posted August 15, 2010 Report Share Posted August 15, 2010 Ok thanks alot. Then i gonna do that. If tyou want to run lights its just as easy to run them on a seperate switch.....FOr the constant on you need to cross the red and black wire though...i forgot to mention that....just follow the two wires should be red and black that go to that start switch.....this will make it hot all the time......just get a shrink wrap butt connector for this Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted August 16, 2010 Report Share Posted August 16, 2010 A honda CR kill switch will plug right in to the banshee's black, white/black wires. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted August 16, 2010 Report Share Posted August 16, 2010 If tyou want to run lights its just as easy to run them on a seperate switch.....FOr the constant on you need to cross the red and black wire though...i forgot to mention that....just follow the two wires should be red and black that go to that start switch.....this will make it hot all the time......just get a shrink wrap butt connector for this huh? Quote Link to comment Share on other sites More sharing options...
12 0 Clock P I M P Posted August 16, 2010 Report Share Posted August 16, 2010 huh? I got all balled up....Inside the healight/on/off swithc on the left side of the handlebar..he wants to remove that..... I just took mine off along with my key switch... You gotta cross two wires to make the bike hot all the time so it will start (i thought it was black and red) AM I thinking of the wrong ones? the only wire i saved was the black/white to wire up my tether Quote Link to comment Share on other sites More sharing options...
AKheathen Posted August 16, 2010 Report Share Posted August 16, 2010 I got all balled up....Inside the healight/on/off swithc on the left side of the handlebar..he wants to remove that..... I just took mine off along with my key switch... You gotta cross two wires to make the bike hot all the time so it will start (i thought it was black and red) AM I thinking of the wrong ones? the only wire i saved was the black/white to wire up my tether yah, the black/white wire is not in the main connector. it hooks up separately with a bullet connector. you can hook that to a killswitch with the other lead hooked to ground, or black Quote Link to comment Share on other sites More sharing options...
Pat the one the only Posted August 16, 2010 Report Share Posted August 16, 2010 a honda cr kill switch will work? i might think about doing that if i ever figure out my starting issue. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted August 16, 2010 Report Share Posted August 16, 2010 Yep it will plug right in to your banshee's wiring harness. The lh switch has 3 plugs. A big one with multiple wires(for the head lights). And a black, black/white stripe wires. These have bullit conectors. These two wires are for the thumb operated kill switch. The black wire is a ground. The black/white stripe wire goes to the cdi. When you ground the black/white stripe wire it kills the engine. Quote Link to comment Share on other sites More sharing options...
12 0 Clock P I M P Posted August 16, 2010 Report Share Posted August 16, 2010 Yep it will plug right in to your banshee's wiring harness. The lh switch has 3 plugs. A big one with multiple wires(for the head lights). And a black, black/white stripe wires. These have bullit conectors. These two wires are for the thumb operated kill switch. The black wire is a ground. The black/white stripe wire goes to the cdi. When you ground the black/white stripe wire it kills the engine. Thanks for the reminder man.......... power...if you want to remove the key switch as well.....you can just cross those wires......those were the ones i was thinking of...... Quote Link to comment Share on other sites More sharing options...
AKheathen Posted August 17, 2010 Report Share Posted August 17, 2010 Thanks for the reminder man.......... power...if you want to remove the key switch as well.....you can just cross those wires......those were the ones i was thinking of...... black/red to black on the harness side of the plug, and black/white to black red on the key switch side Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted August 17, 2010 Report Share Posted August 17, 2010 Thanks for the reminder man.......... power...if you want to remove the key switch as well.....you can just cross those wires......those were the ones i was thinking of...... Yea or you can use a hide a key and put it under the seat. Always leave the key on except when you park it. Quote Link to comment Share on other sites More sharing options...
