what size of domes do i need?
still check the jetting when you switch, and watch out going to lower elevations
oh yes, definatly, i wont forget about that, seems to run richer here at the higher elevation, i was going to lean her out, but since im changing the domes, ill keep it the same, and see what happens, and go from there, once it runs on premium
There are guys locally running 19cc domes, +4 timing on 93 pump. 1300-1500 feet ASL
I'm not one to risk it though. I'd run 20's.
yeah, i talked to a guy, here locally whos got a banshee as well, and he's a big fan of them, he said he had some 20cc domes at home, he said he would drop by, and let me try the 20's out and see what happens
Just to add a lil food for thought.. Not all domes are the same.. Some designs are more prone to detonation then others.. Just because one 19cc dome is fine dont mean the next 19cc dome will be too. This is why its important to know where the domes came from and who designed them.
