Pat the one the only Posted August 15, 2010 Report Share Posted August 15, 2010 Ive had my banshee apart for about 3 monthes, because it was totaled when i got it, and after doing just about everything to it, although it still needs some things here and there, i got to ride it. its really hard to start cold, and this is with stock jetting on a stock motor, although it does have a Rick's hot shot cdi box, but once its warm, it starts easily. also i know it should be more powerful, it has a fare amount of top end, but it isnt very ballsy or that fast, what could be causing this, thanks. Quote Link to comment Share on other sites More sharing options...
sheeowner31 Posted August 15, 2010 Report Share Posted August 15, 2010 Ive had my banshee apart for about 3 monthes, because it was totaled when i got it, and after doing just about everything to it, although it still needs some things here and there, i got to ride it. its really hard to start cold, and this is with stock jetting on a stock motor, although it does have a Rick's hot shot cdi box, but once its warm, it starts easily. also i know it should be more powerful, it has a fare amount of top end, but it isnt very ballsy or that fast, what could be causing this, thanks. well i would guess time to rebulid ur topend if its that hard to start u need pistons then just replace ur plugs make sure ur getting goood spark to Quote Link to comment Share on other sites More sharing options...
1996dragshee Posted August 15, 2010 Report Share Posted August 15, 2010 What's your compression and elevation? Quote Link to comment Share on other sites More sharing options...
Pat the one the only Posted August 15, 2010 Author Report Share Posted August 15, 2010 ive had bikes with really low compression, and they run worse or shut off when hot, my banshee runs just fine when hot, this is wierd. Quote Link to comment Share on other sites More sharing options...
SheezFast02 Posted August 15, 2010 Report Share Posted August 15, 2010 Mine was the same way when I bought it. Finally cleaned the carbs up real good and with help from the BHQ guys on jetting, my Banshee fires up easily. It's great. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted August 15, 2010 Report Share Posted August 15, 2010 X-2 on carb cleaning, comp test. Make sure tester is same length as spark plug, both plugs out ,fuel off, throttle wide open , kick till guage stops moving. Low comp can make it hard to start but that is NOT the only possibility. Quote Link to comment Share on other sites More sharing options...
Pat the one the only Posted August 15, 2010 Author Report Share Posted August 15, 2010 i took both of the carbs apart, cleaned them, put stock jets in them, then i put new fuel lines on it, and a new choke tube, i did all this before i rode it, but it sat with no gas in it, so it should be fine. i just did a compression test on the left cilinder and it read 97 psi, but i didnt get to do it to the right side yet. Quote Link to comment Share on other sites More sharing options...
