Keihin 35 PWK problem
SonOfSand
Hey guys, When I open my throttle all the way the needle is still down in the hole by almost 1 centimter, the slide cant go up any more, it is toucing the bottom inside of the cap. Is this normal? It seems the needle is blocking a lot of fuel. I am Using a CEL needle.
give jeff over at fast a call and he will sell ya a set of new adjusters that eliminates that problem,fairly inexpensive as well.
  • Like 1
Can you push the slide up any more by hand? It sounds like the slide is all the way up and the cable adjuster on top of the carbs are fine. It's normal for the needle to stay in the jet a little.
I just checked, I can not push the slide up anymore with my fingers, will jeff's kit fix this? Is one centimeter normal, that seems like a lot.
Thats correct man.
Here, i had my carbs off and brought one inside and did a quick clip to show you that they are the same.
Mine are 35's with CEL's also and this is how they are fully open which is right. Not sure if its 1 centimeter, but there in there a lil ways anyway.
I can measure with calipers how far exactly if you need me too.
http://s27.photobucket.com/albums/c164/savage_420/?action=view&current=CarbslidesPWK35002.mp4 BHQ :headbang:
I run the taller adjuster on top also, makes a lil bit of difference imo.
Great carbs, hope that helped :cheers:
My 30's were like that and if i remember right my stockers were also.
Thats correct man.
Savage, its hard to tell in that video. If you could measure I would feel a lot better. The guy at sudco said the needle was mostly out. My stock carbs come out further, and the tapper of the needle is so small at that point, its like the needle is not there. What needles are you running?
Thanks for all you're help savage.
