banshee954 Posted August 6, 2010 Report Share Posted August 6, 2010 I have an all stock 2006 banshee. I just installed a K&N air filter with the billet adapter for it with no lid on the air box. When i hit 4th gear and give it more than half throttle it starts bogging and if i keep holding the throttle wide open it will backfire. I have to give it less than half throttle for it to pickup speed again. Gears 1 to 3 work fine at full throttle but i still feel some bogging. The bike did not bogg before when i had the stock air-filter and air-box lid on, it started after i upgraded to the K&N. How do i fix this bogging problem? Quote Link to comment Share on other sites More sharing options...
DallasGDub Posted August 6, 2010 Report Share Posted August 6, 2010 (edited) I have an all stock 2006 banshee. I just installed a K&N air filter with the billet adapter for it with no lid on the air box. When i hit 4th gear and give it more than half throttle it starts bogging and if i keep holding the throttle wide open it will backfire. I have to give it less than half throttle for it to pickup speed again. Gears 1 to 3 work fine at full throttle but i still feel some bogging. The bike did not bogg before when i had the stock air-filter and air-box lid on, it started after i upgraded to the K&N. How do i fix this bogging problem? You have to re-jet when you put in the K&N and take the lid off. Up the main. Edited August 6, 2010 by DallasGDub Quote Link to comment Share on other sites More sharing options...
shee2000 Posted August 6, 2010 Report Share Posted August 6, 2010 did you rejet once you did all that if not do so and DO NOT RIDE IT UNTILL YOU DO list ur mods and someone will help you with jetting Quote Link to comment Share on other sites More sharing options...
madjimmax Posted August 6, 2010 Report Share Posted August 6, 2010 (edited) Definitely get that thing rejeted before you melt it down. I would try at least 2 to 3 sizes bigger then do a plug chop. Oh and welcome to the one and only BHQ:cheers: Edited August 6, 2010 by madjimmax Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted August 6, 2010 Report Share Posted August 6, 2010 like the guys said....you need to rejet. your running super lean at the top end rpms. your goign to need to change your main jet size a few up since your motor is now less restricted from sucking air Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted August 7, 2010 Report Share Posted August 7, 2010 When I put a K&N 2 into 1 filter setup on the wife's bike I had to up the mains AND pilots also to smooth it out when it came on the powerband.Went to a 27.5 pilot and I don't remember what mains. Quote Link to comment Share on other sites More sharing options...
banshee954 Posted August 7, 2010 Author Report Share Posted August 7, 2010 did you rejet once you did all that if not do so and DO NOT RIDE IT UNTILL YOU DO list ur mods and someone will help you with jetting My banshee is 2006 all stock. What size jets do i need and where do i buy them? Quote Link to comment Share on other sites More sharing options...
Sandfrk33 Posted August 7, 2010 Report Share Posted August 7, 2010 Most of the site sponsers should have them. Stock carbs should be around 200 mains. Try 240 and go from there. Elevation /temp also make a difference Quote Link to comment Share on other sites More sharing options...
brugal Posted August 7, 2010 Report Share Posted August 7, 2010 My banshee is 2006 all stock. What size jets do i need and where do i buy them? You have to give us your elevation. Quote Link to comment Share on other sites More sharing options...
banshee954 Posted August 7, 2010 Author Report Share Posted August 7, 2010 You have to give us your elevation. I live in Fort Lauderdale Florida Elevation: 12 feet and the weather temperature is like in the 90's degrees. Quote Link to comment Share on other sites More sharing options...
madjimmax Posted August 8, 2010 Report Share Posted August 8, 2010 I f I was you I would just go get a moose or dynajet kit. This will have new needles and enough different sizes of jets to get you going and more for future mods when needed. Good luck and dont forget to plugchop after changing jets. Also just to let you know dont just go by how it feels. A shee will run its ass off with a lean condition until it melts down. So just do a proper plug chop after changing jets its a must. Quote Link to comment Share on other sites More sharing options...
fastquad02blaster Posted August 10, 2010 Report Share Posted August 10, 2010 I was going to suggest main jet size for this guy but Im running a lot bigger than 200. Isn't that about stock size? Im running a 320 right now and it runs bad ass but uses a lot of fuel. I just ordered 310s and 300s to try to get it to use less fuel. Am I was off base on my quad? All my mods are in my signature. Quote Link to comment Share on other sites More sharing options...
DallasGDub Posted August 10, 2010 Report Share Posted August 10, 2010 I was going to suggest main jet size for this guy but Im running a lot bigger than 200. Isn't that about stock size? Im running a 320 right now and it runs bad ass but uses a lot of fuel. I just ordered 310s and 300s to try to get it to use less fuel. Am I was off base on my quad? All my mods are in my signature. He has stock pipes so it will be diff from yours. Here is a good thread for starting points. http://bansheehq.com/forums/index.php?showtopic=99361 Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted August 10, 2010 Report Share Posted August 10, 2010 I was going to suggest main jet size for this guy but Im running a lot bigger than 200. Isn't that about stock size? Im running a 320 right now and it runs bad ass but uses a lot of fuel. I just ordered 310s and 300s to try to get it to use less fuel. Am I was off base on my quad? All my mods are in my signature. no your not WAY off base....you are running aftermarket performance pipes so you would need to jump up more jet sized cause of that. BUT that does sound like your runnin too big of main jets......however your elevation could be playin a big part of that too... Quote Link to comment Share on other sites More sharing options...
