banshee is not starting constanly flooded
Remove the carbs , flip them over and remove the float bowls. The floats are the black circular plastic pieces that move up and down. Flip the Carb back over and measure the distance from the base of the Carb to the base of where the float comes to rest. Should be 20-22mm.
