Stock and Aftermarket Parts for sale
Here is what I have guys. Feel free to PM me or post if you have questions. I have pictures, so if you want a pic, send me your email and I will get them to you.
2 Full sets of banshee stock a-arms. Both sets are silver, and I will split them up if you need a certain arm. The arms are used, but nothing is loose. 1 of the sets is currently on my bike.
1 set of Works front shocks in Dual rate. Black spring and a white spring on the shock. Sprung for 180-200Lbs rider. Shocks are used and in good shape. These shocks are currently on my bike. I rode with them when I was a 165Lbs, to the fat ass 194 Lbs I am now.
Right and left spindles used and in good shape.
Right and left Stainless tie rods with tie rod end joints.
A set of complete front hubs with bearings and brake discs that are used.
A set of stock jugs at 64mm bore that need a bore job, and the bottom of the transfer ports have been cleaned up on them. I can have Dan Wade at Patriot Racing bore em before I send them.
A set of stock reed cages with what look to be older boyeseen reeds on them, they are used.
A set of stock intake boots with a stock boost bottle, they are used.
A set of used graydon nerf bars with black webbing, has all hardware.
Stock radiator caps that are used.
A used cascade front swingarm chain slider in black.
A red lonestar axle nut (used).
A used rear brake lever.
A used set of 1989 front brake calipers with flexible and hard lines.
A used DG front bumper.
A used Cascade quick release flag mount.
A couple sets of stock banshee swingarm chain adjusters, along with some of the long adjuster bolts. Some brand new and some used.
A used White brothers boost bottle.
A used and polished front brake resevoir cap.
A used stock headlight/kill switch.
A used set of cascade rear fender support brackets.
A used set of blue radiator and tank plastics.
A used aluminum bar clamp with key switch and light mounts.
A used stock radiator.
A brand new rear led tail light and bracket (polished).
A motion pro twist throttle with black oury grips, missing the large screw in adjuster on the throttle.
A slightly used front swingarm pivot bushing (big long one).
A used set of cascade pipe clamps that were on some pt mids.
A used cascade aluminum clutch inset cover.
A used cascade aluminum water pump cover.
A used chrome kickstarter that needs a rebuild kit.
A used set of chrome stock foot pegs that have chrome peeling off them.
A used set of Innova Sand Gear front dune steer tires 22x8x10 on SS (stamped series) aluminum rims. They are the dual rib front steer tires. These are currently on my bike.
A stock used tie rod.
A thumb throttle cable for twin carbs.
A stock used outer tie rod end.
A stock used stator cover with gasket.
Edited by Snopczynski
Here is what I have guys. Feel free to PM me or post if you have questions. I have pictures, so if you want a pic, send me your email and I will get them to you. If you guys get multiple things it may be priced different so you can get a package deal. and shipping will vary depending on what you get, and where you live. Send me your email for pics, I dont want to upload them all into photobucket. There is a lot of them. Not all this stuff is in perfect shape, but I will make sure that you know what kind of shape something is in if you are interested in anything in particular.
2 Full sets of banshee stock a-arms. Both sets are silver, and I will split them up if you need a certain arm. The arms are used, but nothing is loose. 1 of the sets is currently on my bike. For 4 arms your looking at $125.00! For each arm it would $35.00!
1 set of Works front shocks in Dual rate. Black spring and a white spring on the shock. Sprung for 180-200Lbs rider. Shocks are used and in good shape. These shocks are currently on my bike. I rode with them when I was a 165Lbs, to the fat ass 194 Lbs I am now. $200.00
Right and left spindles used and in good shape. $40.00
Right and left Stainless tie rods with tie rod end joints. $30.00
A set of complete front hubs with bearings and brake discs that are used. $40.00
A set of stock jugs at 64mm bore that need a bore job, and the bottom of the transfer ports have been cleaned up on them. I can have Dan Wade at Patriot Racing bore em before I send them. $100 without the boring done. $225.00 with the boring done.
A set of stock reed cages with what look to be older boyeseen reeds on them, they are used. $25.00
A set of stock intake boots with a stock boost bottle, they are used. $20.00
A set of used graydon nerf bars with black webbing, has all hardware. $50.00
Stock radiator caps that are used. $3.00
A used cascade front swingarm chain slider in black. $5.00
A red lonestar axle nut (used). $25.00
A used rear brake lever. $15.00
A used set of 1989 front brake calipers with flexible and hard lines. $45.00
A used DG front bumper. $25.00
A used Cascade quick release flag mount. $10.00
A couple sets of stock banshee swingarm chain adjusters, along with some of the long adjuster bolts. Some brand new and some used. $5-$10 depending on which one
A used White brothers boost bottle. $5.00
A used and polished front brake resevoir cap. $10.00
A used stock headlight/kill switch. $10.00
A used set of cascade rear fender support brackets. $5.00
A used set of blue radiator and tank plastics. $45.00
A used aluminum bar clamp with key switch and light mounts. $15.00
A used stock radiator. $25.00
A brand new rear led tail light and bracket (polished). $25.00
A motion pro twist throttle with black oury grips, missing the large screw in adjuster on the throttle. $20.00
A slightly used front swingarm pivot bushing (big long one). $10.00
A used set of cascade pipe clamps that were on some pt mids. $10.00
A used cascade aluminum clutch inset cover. $10.00
A used cascade aluminum water pump cover. $30.00
A used chrome kickstarter that needs a rebuild kit. $10.00
A used set of chrome stock foot pegs that have chrome peeling off them. $20.00
A used set of Innova Sand Gear front dune steer tires 22x8x10 on SS (stamped series) aluminum rims. They are the dual rib front steer tires. These are currently on my bike. $120.00
A stock used tie rod. $5.00
A thumb throttle cable for twin carbs. $10.00
A stock used outer tie rod end. $5.00
A stock used stator cover with gasket. $10.00
pics send to ericbarbier59@yahoo.com.... price shipped to 70341
Are the shocks for long travel a arms? email pics of a arms and shocks carlcidortiz@yahoo.com
pics to djheathen@gmail.com definately interested in at least the pivot tube,pipeclamps, and fender supports.....dibs! :D
