mailman Posted July 29, 2010 Report Share Posted July 29, 2010 Are there any Honda hubs that fit on the banshee axle? I have a friend who has a bunch of Honda 110 pattern wheels but is running a banshee axle. I know he could drill the rims for the 110 pattern but is there any Honda hub or a hub he can get that will fit the banshee axle and have a Honda bolt pattern? He did find an aftermarket set of hubs that will do the trick for $150 but if there is a cheaper way to go then let's here it. Thanks guys, Mailman Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted July 29, 2010 Report Share Posted July 29, 2010 Are there any Honda hubs that fit on the banshee axle? I have a friend who has a bunch of Honda 110 pattern wheels but is running a banshee axle. I know he could drill the rims for the 110 pattern but is there any Honda hub or a hub he can get that will fit the banshee axle and have a Honda bolt pattern? He did find an aftermarket set of hubs that will do the trick for $150 but if there is a cheaper way to go then let's here it. Thanks guys, Mailman I believe that Lonestar makes a hub that is Yamaha splines with a Honda bolt pattern. That is the only option I know of, but you could also check DuraBlue, RPM, or some of the other drivetrain/suspension manufacturers. Quote Link to comment Share on other sites More sharing options...
toytech Posted July 29, 2010 Report Share Posted July 29, 2010 Are there any Honda hubs that fit on the banshee axle? I have a friend who has a bunch of Honda 110 pattern wheels but is running a banshee axle. I know he could drill the rims for the 110 pattern but is there any Honda hub or a hub he can get that will fit the banshee axle and have a Honda bolt pattern? He did find an aftermarket set of hubs that will do the trick for $150 but if there is a cheaper way to go then let's here it. Thanks guys, Mailman check the bolt pattern on a blaster hub I beleive it is 110 and fits a banshee axle Quote Link to comment Share on other sites More sharing options...
hank 024 Posted July 29, 2010 Report Share Posted July 29, 2010 The blaster hubs will work I have used them before with the shee axle Quote Link to comment Share on other sites More sharing options...
chugger Posted July 29, 2010 Report Share Posted July 29, 2010 blaster hubs are 4x100 so thats a no go for the honda 110 Quote Link to comment Share on other sites More sharing options...
mailman Posted July 30, 2010 Author Report Share Posted July 30, 2010 Thanks for all the help guys! I just found a set of aftermarket ones from a member so I will grab those. Quote Link to comment Share on other sites More sharing options...
