zachwells229x Posted February 28, 2016 Report Share Posted February 28, 2016 I'm getting .4 ohms from my coil .02 higher than normal? Is this a problem or could it simply be a slight variation in the testing equipment Sent from my Z812 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 28, 2016 Report Share Posted February 28, 2016 I'm getting .4 ohms from my coil .02 higher than normal? Is this a problem or could it simply be a slight variation in the testing equipment Sent from my Z812 using Tapatalk clean up the connector spades and try again Quote Link to comment Share on other sites More sharing options...
zachwells229x Posted February 28, 2016 Report Share Posted February 28, 2016 What would determine a bad coil too high or too low of a reading ? Sent from my Z812 using Tapatalk Quote Link to comment Share on other sites More sharing options...
zachwells229x Posted February 28, 2016 Report Share Posted February 28, 2016 clean up the connector spades and try againWould a higher reading mean there an issue or a lower reading? Sent from my Z812 using Tapatalk Quote Link to comment Share on other sites More sharing options...
