steering stem play
blast off
Hi guys I was wondering if I could get some help with this little problem I have. When Im on my shee and I pull up on the handle bars there is some play, It knocks up and down when i pull on it. There are no loose bolts or anything and the nut at the bottom of the steering stem looks ok but for some reason there is play. Has anyone seen this before? Is that a bushing at the bottom of the nut? can it be replaced? Any help is appreciated.
Thanks,
Also, there is a retainer that screws in the frame to hold bearing, etc. If this loosens, you will also get play in the stem up and down.
im gonna have to look ito that too, do I need to take off the radiator to check this stuff or is just removing the plastics sufficient enough?
