WeSt CoAsT TrUtH Posted July 22, 2010 Report Share Posted July 22, 2010 Whats up guys im doing my first tear down of the entire bike because i have to rebuild the tranny. any suggestions of things i can and should do while i have the motor apart? any feedback is appreciated Quote Link to comment Share on other sites More sharing options...
Sandfrk33 Posted July 22, 2010 Report Share Posted July 22, 2010 What mods do you have now? Quote Link to comment Share on other sites More sharing options...
brugal Posted July 22, 2010 Report Share Posted July 22, 2010 Modify your shift star Get a billet impeller just to name a couple Quote Link to comment Share on other sites More sharing options...
AdrenalineJunky Posted July 22, 2010 Report Share Posted July 22, 2010 Yep those are 2 things my bike didn't have and while I got it apart I ordered the same things. Also: adjustable timing plate, pancake bearing off the top of my head. Throw a new clutch in it while your at it. You can get a Tusk one for like $50. Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted July 22, 2010 Report Share Posted July 22, 2010 Depends on how much you want to spend. You could get the shift drum with the bearing mod from WCR. Also as mentioned, shift star, shift shaft mod, bushing for the spring that goes on the eccentric screw adjustment. New bushing for your idler gear ect.. Check your basket for wear and tear, if its grooved real bad, get ahold of FAST and order a billet one. Check your inner and outer clutch hubs for wear. Its a good idea to replace those anyways since they are only $55 bucks for the pair. Pancake bearing is a good idea as well. That would pretty much do all the tricks to your trans, unless you want a duneable!!! Quote Link to comment Share on other sites More sharing options...
SonOfSand Posted July 22, 2010 Report Share Posted July 22, 2010 while you have the cases apart drop a 4 mil crank in and have the cylinders ported.... best decision of you're life!! Quote Link to comment Share on other sites More sharing options...
jasons Posted July 22, 2010 Report Share Posted July 22, 2010 Whats all this about the pancake bearing mod?? can some 1 shed me some light? Thanks the pancake bearing is so you dont weld the clutch push rod to the ball. if you know how to ride you dont need it. lot of people weld the rod to the ball when coming down the hill with the clutch pulled in. just ride down the hill in gear and you wont have this problem. Quote Link to comment Share on other sites More sharing options...
