2strokespirit Posted July 23, 2010 Report Share Posted July 23, 2010 (edited) James, make sure you did not put the wrong float bowl on the wrong carb when you opened them, they look identical, but are not, the one with the jet inside the bowl goes on the carb with the choke lever... This is the most common issue with your type of syntems... If this is the case, your choke will not work...... Edited July 23, 2010 by 2strokespirit Quote Link to comment Share on other sites More sharing options...
