Boost Bottle or stock balance pipe ?
Hay just want some info is the boost bottle better then the stock balance pipe ? I read that it improve s throttle response and low-end power . But is it worth it and can u feel a deference or not and just stick with the stock ? ....
Ok where can I see them do u have a pic and who makes them what name brand and about how much do they run. I have stock carbs. I still have to do a top end rebuild on this I just got it about a month ago and was missing parts. So frist my working on getting it to run.... Just making a list of what aftermarket parts I should get.... Thanks.
Chariot performance, one of the site sponcers, they are around 150, the best way to go is one of theese intakes
Don't use a boost bottle, they put excessive strain on your intake boots and will crack them causing an air leak and leaning out your air/fuel mixture. Stick with the stock pipe or upgrade to one of the aforementioned intakes.
and dont ask anymore stupid questions, use the search function next time, this has been talked about a million times too many already.
and you sound like a new person here so welcome.
Sure glad I didnt ask a "stupid question", give the guy a break, hes new here.
Welcome bro!
If youve been looking for a while, then you know how helpful this place can be, use it wisely, and yeah, Ill give you a helpful tip about a boost bottle, stick it under your bottom end when its time to rebuild, thats all theyre good for, and theyll hold your engine block at the exact angle you need!!
