+4 stroker help.
I've heard not to go through trinity, so I'm now asking you guys for help.
6 Years on the shee motor, and it's running about 93 on the compression test. . . Sad right? Supposed to be around what 140 ish? (Stock) I can't complain though. Never had a 4 stroke last this long in my life. Blew my 450 up in 3 months. Can't seem to pop the 350 dually!
I've decided to rebuild it, before something breaks. If I'm rebuilding, I want a +4. Exactly what parts do I need? Where do I start? etc. Do I need a new head? any porting? jetting, etc. Even if you can give me links to each part I need would be great. I've read the thread here of why trinity's bad, so where else would I buy a stroker kit? or the parts that I need.
Walk me through this like I'm retarded, because this is my first two stroke motor and I'm still learning.
Thanks!
http://www.bansheehq.com/index.php?option=com_content&task=view&id=20&Itemid=35 Empty your wallet and charge the rest !! Seriously tho, it's all the site sponsers, see what all they offer. Also , what do you currently have on it ? Pipes , carbs, other bolt ons. Biggest facor is how much you want (or can) spend and how far do you want to go !! Edited by Larry's Shee
I'm ONLY looking to do what I need to, in order to properly run a +4. Bare minimum for the performance. Currently, it has a team ALBA folded air filter, FMF SST pipes, with cut Titanium 2 silencers. That's it. :)
4mill long rod stroker crank from fast $435
http://www.farmandsandtoys.com/partdetail.asp?partid=78
Pair of Wiseco 795 (for the long rod) series pistons $164
http://www.farmandsandtoys.com/partdetail.asp?partid=77
Noss Machine Cool Head $195 (bhq members get 10% off)
http://www.nossmachine.com/banshee_heads.htm
Custom cut stroker domes. I would get them through who ever does your porting. They will know what size of domes are needed for there port work for running a spacific fuel. Different port jobs respond differently so you might need a little smaller or larger dome.
Porting not required it will run but it wont be near as fast as it could be. A ported stock stroke banshee will be a lot faster than a non ported 4 mill, so I would say it is required. There is no better time to do porting than when your doing a top end. Who you go through that choice is going to be up to you. There are a lot of good builders on here and I dont think you would be un happy with any of them. I would recomend Jeff at FAST, but he is going to be closed until july 22. Around $350
http://www.farmandsandtoys.com/services.asp
You should also get the pistons from who ever your going to have do the port work, and bore. That way they can measuer the cylinders and just bore the bare minimum.
josh
thanks a bunch for the help. I'll send it out for porting some time soon. I'll probably get a hold of FAST and see what they can do for me. I'm worried about reliability though too. Just because I want a fast machine, doesn't mean I'm willing to sacrifice hp for reliability. I've got 6 years on this motor and it still runs like a champ, I just think it's time to do a rebuild. It's nice knowing that when my friends come back up north where I live, I can go turn the key, and kick it twice and have a nice running machine. What kind of problems may I have as far as reliability with a +4 with a woods porting job and cool head? Has anyone run these for a long time? I typically ride almost every day for at least a little while, and normally on weekends all day. I really really don't want to spend over a grand to have it run amazing for a month and have issues. Not that I'm saying it will, but I'm worried about leaving stock stock settings for aftermarket ones. Bottom line question is what kind of reliability will I have with a stroker? Can I count on it lasting another 6 years? haha At least 1-2.
You shouldnt see any loss in reliability. The long rod 4 mill has conecting rods that are 5 mill longer than the oem ones. This helps reduce the side load on the piston skirts. The cool head will be fine as long as you dont pinch an o ring when you install it. I reuse the orings when I have taken mine appart.
There is a dune ported 4mill top end for sale in the classifides. He was asking 375 for the cylinders, and domes. I believe one piston was bad. I would just buy a new set instead of running one used piston and one new one.
