jetting pwk 35mm help
3SGTE
Still way too rich. Try a 162
I be afraid to run leaner of 175 for reliability
I don't make lot off drag racing
when I run is it for one full tank of gaz ...50 miles of trail riding
I want my engine run more cool than hot
If every body say 162 don't hurt my engine in long run I try it
tank
I´m not an expert - but I´am 100% sure that you can´t hurt your motor just doing one plug test with those 162´s. If those 162´s are too lean you can tell it before you even try to do your test run. When you find out your "perfect" jetting you can go up 1 or 2 size that you can have your peace of mind. When you find out the "good" jetting you can see alot more power.
I have 35.5 PWK´s and I have 40 pilot (still rich), needle in the midle and 152 main (still rich).
And these settings with 83*F and 300-330ft ASL. Because it will be hot for a long time I will get smaller mains (148,150) and 38 pilots.
-Pasi S.
(sorry my finglish)
Just came back from the local shop. I bought a set of 150´s and 145´s. They didn´t have those 148´s. Also the smallest pilots was 40 witch I already have. Now it´s time to clean my filters and carb´s and see how it goes...
-Pasi S.
