jeramie Posted July 4, 2010 Report Share Posted July 4, 2010 so i was riding my bike yesterday and it all of a sudden lost power. the rings are probably just fried but i've never owned a shee before and was wondering if it might be anything else. how much compression should each cylinder have and is it very difficult to replace the top end on these bikes? Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted July 4, 2010 Report Share Posted July 4, 2010 A top end rebuild is pretty easy, but you'll have to take the cylinders to a machine shop, to have them checked out, before you order your pistons, and rings. Once you have the pistons, they can bore, and hone the cylinders. If your compression is 100, or less, it's definately time to rebuild, or if one cylinder is 5 lbs off from the other one, it's rebuild time. Quote Link to comment Share on other sites More sharing options...
jeramie Posted July 5, 2010 Author Report Share Posted July 5, 2010 yea, ran a compression test on it and it had 60 psi in one and wouldnt show anything on the other cylinder. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted July 5, 2010 Report Share Posted July 5, 2010 oh, yah, sounds like you probably melted her down. look for signs of airleaks, or pluged up carbs/fuel screen Quote Link to comment Share on other sites More sharing options...
jeramie Posted July 5, 2010 Author Report Share Posted July 5, 2010 yea theres a fatty hole in the top of my brake side piston and it looks melted. but the other piston is just fine and dandy. what do you think might of caused this. Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted July 5, 2010 Report Share Posted July 5, 2010 yea theres a fatty hole in the top of my brake side piston and it looks melted. but the other piston is just fine and dandy. what do you think might of caused this. Lean condition is my guess. Like AK sais, look for signs of an air leak on that side. Intake boots, carb came out of the boot ect. Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted July 5, 2010 Report Share Posted July 5, 2010 Now would be a great time to get some porting done. Replace all of your top end gaskets, and do a leak down test, before you start it up. Quote Link to comment Share on other sites More sharing options...
jeramie Posted July 6, 2010 Author Report Share Posted July 6, 2010 the previous owner already did the porting. what exactly is a leak down test and how do i do it. Quote Link to comment Share on other sites More sharing options...
