RDZ Head Problems. Need some help
b-nasty
Putting the 421 toghether and did a compression check, Only had around 75psi and Couldnt get a squish reading. Dont know what the heck is going on. Everything seemed ok when I took the head off. Its a 4mm cranks, cub cylinder, blaster pistons, and a RDZ head with 20cc domes. Do they have to be RDZ domes? Let me know what you guys think. thanks
Domes for a blaster piston are different than banshee pistons by quite a bit. Also domes for a stock cyl 4 mil crank are different. You probably have a bad match on something. If you call Jeff at FAST he is very good at getting that lined out.
  • 2 weeks later...
also cut domes will not work because of the deck height being almost zero,so if your domes are cut for a 4mil squish would be non existent
Not really...it would be 2mm plus the actual squish...LOL.
Do yourself a favor...measure deck height. That's how far the piston sticks out of the bore at the edges.
It is quite possible there is a mixup and you got the wrong parts. It happens.
still kinda sounds like you have about .010 thous too thick of a base gasket but should be close enough unless you are still about 10-20 psi short of what you are wanting it may be short on bottomend since its a pumpgas motor depending on what you weigh.
