Judge1 Posted June 28, 2010 Report Share Posted June 28, 2010 How do I tell what side the a arms go on? They are and older set of burgard +2+1 sport arms. Does the straighter portion of the arms go to the front or the back? Thanks Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted July 6, 2010 Report Share Posted July 6, 2010 When you put the lowers on, the shock mount on the a arm should line up with the shock mount on the frame. The uppers will only fit one way and clear the shocks. Also, on each arm you will notice that the ball joint is not centered straight out from the pivot tube, the offset of the upper arm will be the opposite of the lower arm on each side. Quote Link to comment Share on other sites More sharing options...
Judge1 Posted July 9, 2010 Author Report Share Posted July 9, 2010 Thank you!!! I thought I was not going to get any input on this. That is how I have them mocked up now but thought it looked a little funny. Quote Link to comment Share on other sites More sharing options...
