Fastassbanshee96 Posted June 26, 2010 Report Share Posted June 26, 2010 Is there a way to remove the tors without buying the new cable and caps. Mine are already done just trying to get some info for someone in az. If you can do this please give detailed discription on how to. Quote Link to comment Share on other sites More sharing options...
Phelps Posted June 26, 2010 Report Share Posted June 26, 2010 no Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted June 26, 2010 Report Share Posted June 26, 2010 You can eliminate the problems the TORS causes by unplugging the wires at the carbs and thumb throttle and then unplugging the TORS control box under the left side of the fuel tank next to the coil. This disables the TORS system and the bike will run like it is not there at all, but you still have the big, ugly carb tops there in the way. The only way to get rid of them is to buy the eliminator kit, or at least the carb tops and new cable. Then you will have no way to adjust your idle speed, unless you buy the idle screw kit. Quote Link to comment Share on other sites More sharing options...
Phelps Posted June 26, 2010 Report Share Posted June 26, 2010 You can eliminate the problems the TORS causes by unplugging the wires at the carbs and thumb throttle and then unplugging the TORS control box under the left side of the fuel tank next to the coil. This disables the TORS system and the bike will run like it is not there at all, but you still have the big, ugly carb tops there in the way. The only way to get rid of them is to buy the eliminator kit, or at least the carb tops and new cable. Then you will have no way to adjust your idle speed, unless you buy the idle screw kit. no was a lot easier lol Quote Link to comment Share on other sites More sharing options...
Fastassbanshee96 Posted June 26, 2010 Author Report Share Posted June 26, 2010 That's what I thought. I was just double checking. Thanks. Quote Link to comment Share on other sites More sharing options...
