Boss429 Posted June 25, 2010 Report Share Posted June 25, 2010 I have a 1997 banshee that starts overheating after a 15 minute ride. it also bogs at low end and sputters a bit at top end. it starts dropping coolant from the overflow hose near the radiator, the compression on the bike last time i checked was about 120psi on one cylinder and 115psi on the other, it has a 4mill crank with original cylinders and a mild port and the stock head has been shaved. some people have told me that it overheats because of the low compression, and i don.t know whether to put a new top end or maybe the head was shaved a bit much that it lowered the compression that much, i bought this bike as is like 2 months ago any information would really be appreciated thanks. Quote Link to comment Share on other sites More sharing options...
Phelps Posted June 25, 2010 Report Share Posted June 25, 2010 the waterpump has probably fell apart due to years of use and no coolant changes. Quote Link to comment Share on other sites More sharing options...
Boss429 Posted June 25, 2010 Author Report Share Posted June 25, 2010 the waterpump has probably fell apart due to years of use and no coolant changes. thanks for the reply i will check the waterpump asap but i did change the coolant when i first got it by the way im running stock carbs with a 320 main jet and 55 pilot jet. Quote Link to comment Share on other sites More sharing options...
Phelps Posted June 25, 2010 Report Share Posted June 25, 2010 thanks for the reply i will check the waterpump asap but i did change the coolant when i first got it by the way im running stock carbs with a 320 main jet and 55 pilot jet. as quick as it's getting hot i would say no water is moving. just check the pump and gear and post back when you find out rather it's broke, or not. Quote Link to comment Share on other sites More sharing options...
Boss429 Posted June 25, 2010 Author Report Share Posted June 25, 2010 as quick as it's getting hot i would say no water is moving. just check the pump and gear and post back when you find out rather it's broke, or not. thanks for all your help ill get back to you as soon as im done thanks Quote Link to comment Share on other sites More sharing options...
LS1Inferno Posted June 26, 2010 Report Share Posted June 26, 2010 check the radiator also, i had a 97 also that would do the same thing, pump was fine, jetted perfect, turns out the radiator was plugged more than anything on the bike which caused it to overheat Quote Link to comment Share on other sites More sharing options...
yamahaman244 Posted June 26, 2010 Report Share Posted June 26, 2010 as quick as it's getting hot i would say no water is moving. just check the pump and gear and post back when you find out rather it's broke, or not. Um Idk don't you guys usally say 27.5 for your piot not 55?? Proby woulndt cause over heating but maybe the sputtering Quote Link to comment Share on other sites More sharing options...
banshee#44 Posted June 27, 2010 Report Share Posted June 27, 2010 Um Idk don't you guys usally say 27.5 for your piot not 55?? Proby woulndt cause over heating but maybe the sputtering we say 27.5 pilots because the stock 26mm banshee carbs goes my incriments of .5.... so why would i say 55 pilot when on the pilot jet it actually says 27.5 haha Quote Link to comment Share on other sites More sharing options...
TNTS355 Posted June 27, 2010 Report Share Posted June 27, 2010 Even if your impeller not bad, I would change it out to a billet one anyway. Quote Link to comment Share on other sites More sharing options...
