dynoport big volume pipes
gofast5
I traded off some fmfs for some hand coned dynoports. Apparently their big volume dynoports any one have any experience with them? Only problem is I didnt get silencers but I might be able to snag another set with sileners for dirt cheap. Its kind of akward both sets have a dent in I want to say the right header on the back side and they both have a little crack and weld in them.
Im at the beach so as soon as I get home ill post some pics. By the way I didn't trade him my silencers. Why are you saying to get my fmfs back? They were in decent shape I just though these were pretty cool and the kid gave me a deal I couldnt refuse. My pipes, cylinders, pistons, reeds cages and stock carbs for this kids cylinders, cool head, 2 into 1 carb, and the dynoports. He also gave me a bunch of misc parts he didnt want, pretty much a whole bottem end but the cranks shot. Some shrouds, used mxr6s, stock pipes, clutch side cover and alot of other random things.
Edited by gofast5
Because the pipe sucks the big one. The 2:1 pipe is supose to be a low end pipe, but a pair of Pro Circuit pipes has just as good low end pull but will rev out way better on the top end.
The same goes for a the 2:1 carb. A pair of Keihin 28mm carbs will out perform a 2:1 any day.
No lol sorry I didn't explain good enough. Its not a big volume 2 into 1 its 2 seperate dynoport big volume pipes. Twin pipes just like a t5, dmc, or any other pipe but they are prety big more like an inframe drag pipe. Sorry for the mix up! :jesterlaugh:
I understood what it was and I stand by my comment still. Its also defintiely a bad idea to run a 2 into 1 intake with those pipes.
My comment was more toward the other post. I'm not going to use the 2 into 1 I have a guy who was interested in one and I could make alot more money off it then my stock carbs. Im going to be running pwk 28s. What type of power band are these pipes why do you recommend me changing them? I remember for blasters they were a real good pipe but I know the banshees a whole other story.
My current setup is pwk 28s running pods will be switching to my cfm air box, +4 or +5 timing havent decided what I will be using yet, ported cylinders, going to port my reed cages, stock stroke long rod crank, big bore jugs wiht trinity IV porting, and probably 22cc domes. I might port the cases its just a play bike it had plenty of power with more or less stock porting, t5s, and the 28s.
