SheezFast02 Posted June 25, 2010 Report Share Posted June 25, 2010 Can anyone do me a favor and post a pic of the gearcase vent so I can see what it looks like? I'm looking at two different possible pieces on F.A.S.T website and I want to be sure I choose the right one. The hole is on the left side of the case, right behind the left cylinder. I'd like to order it as soon as possible so I don't get any critters in there. Your help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted June 25, 2010 Report Share Posted June 25, 2010 Can anyone do me a favor and post a pic of the gearcase vent so I can see what it looks like? I'm looking at two different possible pieces on F.A.S.T website and I want to be sure I choose the right one. The hole is on the left side of the case, right behind the left cylinder. I'd like to order it as soon as possible so I don't get any critters in there. Your help would be much appreciated. The hole in the case behind the left cylinder does NOT get a vent. If you look at that hole, you will see that it goes all the way through the bottom case and is open to the ground. It is there to give a drain for the crud that accumalates on top of the cases under the carbs. The case vents in the rear of the upper case under the rear motor mount, and there is a second case vent comming out of the clutch cover by the water pump. Hope this helps you. Quote Link to comment Share on other sites More sharing options...
midlifecrisis Posted June 25, 2010 Report Share Posted June 25, 2010 Can anyone do me a favor and post a pic of the gearcase vent so I can see what it looks like? I'm looking at two different possible pieces on F.A.S.T website and I want to be sure I choose the right one. The hole is on the left side of the case, right behind the left cylinder. I'd like to order it as soon as possible so I don't get any critters in there. Your help would be much appreciated. X2, the case vent hole is right in front of case stud #16, but Id love to see a pic of it too, I asked 2 weeks ago for this! Quote Link to comment Share on other sites More sharing options...
mailman Posted June 25, 2010 Report Share Posted June 25, 2010 #6 in the diagram. You can click, hold and move the diagram so you can see the breather. Breather Quote Link to comment Share on other sites More sharing options...
SheezFast02 Posted June 25, 2010 Author Report Share Posted June 25, 2010 The hole doesn't look to be on that diagram. It's right infront of the #25 bolt in the diagram, but again, it doesn't show it there. So no need for me to do anything about this? Thanks, guys. I appreciate the help. Quote Link to comment Share on other sites More sharing options...
