livealatimmy Posted June 25, 2010 Report Share Posted June 25, 2010 Ok I'm attempting to put my banshee back together and do know that the orings that came in my gasket kit are for the exhaust. My question is that do you have to use the orings?? I got power pro exhaust and when I put the oring on and then slip the headpipe on the oring wants to push out. Am I just installing them wrong or do some aftermarket exhaust systems not use the orings... Quote Link to comment Share on other sites More sharing options...
Phelps Posted June 25, 2010 Report Share Posted June 25, 2010 if you like oil all over everything than dont run them. i use a dab of oil and twist the pipe on and have never had a problem. Quote Link to comment Share on other sites More sharing options...
Drewski Posted June 25, 2010 Report Share Posted June 25, 2010 As far as I know, you want to use the O-rings unless you want a gummy mess on your motor. My rockets use stock exhaust o-rings fine. Maybe try greasing them a bit. Quote Link to comment Share on other sites More sharing options...
livealatimmy Posted June 25, 2010 Author Report Share Posted June 25, 2010 As far as I know, you want to use the O-rings unless you want a gummy mess on your motor. My rockets use stock exhaust o-rings fine. Maybe try greasing them a bit. Thanks guys.. Stupid question I know but I had to ask. Quote Link to comment Share on other sites More sharing options...
