Shift star
Was curious if I could mod my shift star myself. I was comparing a OEM to a modded star and it looks like something I can do. Anyone on here done there own shift star mod?
I have also talked with a few banshee guys who told me they modded there own timing plate to advance it 4* how hard would something like this be to do? Anyone have any pictures of there self modded timing plate?
I modded mine. I bought one for the two bikes I had ground on the tits and matched them up.
Really simple to do, take you 1/2hr tops on a bench grinder.
Do the shift shaft also when you have it out.
Heres a thread i have pics in from a while ago.
http://bansheehq.com/forums/index.php?showtopic=126900&view=&hl=shift%20shaft%20mod
More info that you will want to read. http://bansheehq.com/forums/index.php?showtopic=127372&view=&hl=shift%20shaft%20mod
Ill try and find some pics of a stock plate ive ground on a while back, it's really damn easy to do also.
But there only 35 on ebay for ones already done from the factory.
No, just the one nub that would be between 6th-1st don't shave down. But you know what, it wont hurt anything if you do that one also, just its more work for nothing as the star does not go past 6th gear so, once its in 6th, thats it and the drum wont turn past that.
Between 1st and 6th would be neutral correct? From looking at your picture again looks like all but 1st has been ground down. Sorry for making this difficult I'm just having a hard time understanding.
No. Between 1-2 is neutral, it's the lil half moon cut out. No need to grind down between 6-1 gears, but wont hurt anything if you do. Make sure you do not let neutral touch the wheel on your grinder at all!!!
In the pic, im in first gear.
Blue lock tight the screw that holds the star in when your done afterwards also.
Here, i messed with my pic so you can see what all is going on and what shit it and what it all dose.
Click the pic bigger so you can read it. \/\/\/\/\/
Understand now?
Its really no big deal to do.
