why change?
midlifecrisis
So that sums it up!
Why change from a stock setup to an aftermarket one, or even a YFZ front end? I presently have TCS fronts with rezzies on a stock front end. Are the stock ones crappy?
Also, how do you tell the difference between an A to a J front end?
because stock arms suck... limited travel... u will get a smoother ride and wider stance wit new arms... if u get wider then stock... some ppl jus make a lighter stock style... more for drag racing....ur riding style should be easy to chose a arm for... most go wit +2+1... as that means it will be plus 2 wider than stock... and 1plus forward... than stock... hope i helped....
thats a j-arm front... easy to spot... cus the upper arm is a j shape... only on 87-89 models....ok for most... but extream whoops and jumps fucks them up....
a-arms are easy to spot... as upper arm is in shape of an "A"..... and much stronger... been on all models since 90...
and a shot of a sexy shee wit aftermarket fronts...
DiSkOe*1
Honestly, if your happy with the way its handling, there is no imediate need to change them. Once they wear out however, that would be a good time to get your aftermarket arms. You will need to setup your shocks to accomadate the +2 arms though. The advantage of +2 arms is stabality, adjustability and maybe weight savings, if that matters to you or not. I don't think you gain much travel if any when you switch to +2 arms, unless they are long travel.
That's some good advice right there. As far as setting up the shocks to run +2's, 90% of people can get away with just cranking down the preload a little bit to accommodate the extra leverage on the spring.
All great advice fellas, thanks!
What about the YFZ front end then, is it wider than our stock A arms? Is it lighter, better? Do they bolt right up, or what is involved with the change?
By the way Matt, nice pic on the avatar, someone you know, you lucky guy!
I just completed my YFZ swap (Shocks A-arms and Banshee spindles). The setup is awesome, steering is a little harder than stock but not a problem. I ride mostly fast trails and small jumps and it works perfect for me. High speed stability is awesome with the added width and caster. Only drawback I see is it lowers the front end about 1 inch. I did my before and after measurements and found that it was closer to +3 than +2.
