HELP! Water In Transmission!
How is the coolant level?
It wont blow white smoke because the oil doesn't lubercate any engine parts.
Coolant was empty, I noticed the white stuff coming out the crank overflow dripping everywhere, hasnt been happening long I dont think because i haven't seen it on the shop floor. put water in and it was hot but i dont *think* i overheated it very short ride.
Change the pump seal, it's leaking. Do the bearing also since your in there. 1hour job messing around.
What water pump you running? Sometimes cheap after market billet water pumps have shitty shafts. The seal wears a groove in the shaft and that is what leaks. Good seal and all but the shaft is the problem. Just make sure while you have it apart that the shaft isn't grooved. No good seal will fix that.
SP
