jst854 Posted June 17, 2010 Report Share Posted June 17, 2010 I am just getting my shee together finally and ran into a problem when trying to get the carbs on. THey are 34mm Mikuni Flat slides and I have the banshee manifold ( intake boots) for a PJ34, PWK 33-35 and the carbs physically fit in the boots, however the bottom of the carbs are hitting the clutch cable and clutch lever on the case by a good half of an inch. Is there something I am doing wrong, or some special trick to this? Quote Link to comment Share on other sites More sharing options...
Phelps Posted June 17, 2010 Report Share Posted June 17, 2010 your going to need to get some reed spacers to kick the carbs up and back away from the clutch lever Quote Link to comment Share on other sites More sharing options...
spurdy Posted June 17, 2010 Report Share Posted June 17, 2010 Or an after market intake to change the angle of the carbs. Sometimes you can bend the actuator arm down enough to miss the bowl. When I ran 34 Mikunis I had reed spacers and a Trinity manifold and they cleared ok. SP Quote Link to comment Share on other sites More sharing options...
