jst854 Posted June 16, 2010 Report Share Posted June 16, 2010 I just got a set of 34mm Mikuni Flat Slides carbs and was wondering what throttle cable i have to use with them. I currently only have a tors throttle cable and that obviously doesnt fit, Does a stock throttle cable w/ tors eliminated work with these carbs, if not where could I find a cable that will work. Thanks Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted June 16, 2010 Report Share Posted June 16, 2010 They use the same throttle cable as the TORS eliminator kit. I want to say they are aound $25 shipped from us. I'll have to check for sure. Quote Link to comment Share on other sites More sharing options...
jst854 Posted June 17, 2010 Author Report Share Posted June 17, 2010 They use the same throttle cable as the TORS eliminator kit. I want to say they are aound $25 shipped from us. I'll have to check for sure. I did use this cable but it seems too short, almost like the carbs are at 1/4 throttle with out even pulling the throttle. I am also having problems mounting the carbs. I have the carb boots for PJ34, PWK 33-35 and the bottom of the carbs are hitting the clutch cable and clutch lever on the case, is there a special way to mount these? Quote Link to comment Share on other sites More sharing options...
