CFH87 Posted June 15, 2010 Report Share Posted June 15, 2010 (edited) I was thinking of getting a new set of shocks soon and was wondering if these Pro Series Black Widow shocks front and back would be worth a go? I'd like to get the dual rate but what the diff between the dual rate and tripe rate springs? And im rollin on an 87 j frame banshee. Should I just wait to get an a arm frame and get extended arms? thanks Edited June 15, 2010 by CFH87 Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted June 15, 2010 Report Share Posted June 15, 2010 I was thinking of getting a new set of shocks soon and was wondering if these Pro Series Black Widow shocks front and back would be worth a go? I'd like to get the dual rate but what the diff between the dual rate and tripe rate springs? And im rollin on an 87 j frame banshee. Should I just wait to get an a arm frame and get extended arms? thanks The black widows are a very good shock. You might want to double check with Works, as I don't think they make a stock length for the banshee. The black widows were designed to be the competition to Elka's, or the Fox Clickers. Very comparable and a pretty sweet looking shock. Triple rate is a complete waste. On a shock this short, the third spring only has about a 1/2" of travel before the slide hits the slide stop, or the other slide. Go with a dual rate and you'll be set. Quote Link to comment Share on other sites More sharing options...
jayzx10r Posted June 15, 2010 Report Share Posted June 15, 2010 (edited) X-2 on the triple spring shock thing.... Edited June 15, 2010 by jayzx750 Quote Link to comment Share on other sites More sharing options...
CFH87 Posted June 15, 2010 Author Report Share Posted June 15, 2010 so the widows would be set up for a longer deal like +2 a arms ? Quote Link to comment Share on other sites More sharing options...
