252wheelieking Posted June 13, 2010 Report Share Posted June 13, 2010 1) What type of aftermarket exhaust do you have? (FMF Gnarly pipes with Power Core 2 silencers) 2) What type of airfilter do you have? (Dual K & N filters) 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all ( D) 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) (Sea level) 5) What size pilot jets are you using? (#55) 6) What size main jets are you using? (#152) 7) What temperature is your Banshee jetted for? (Don't know they came in the carbs) 8) Do you have a port job? (No, stock cylinders) 9) What kind of carbs? (PJ Keihin) 10) What size carbs? (35mm) Quote Link to comment Share on other sites More sharing options...
Pasi S. Posted June 13, 2010 Report Share Posted June 13, 2010 I´m not an expert but... I think you are too rich on your jets. That´s why it won´t make any rpm´s. Clean up your filters and put in new spark plugs and it´s also a good thing to clean your carbs also. Then I would go a smaller size pilots and mains. I have ported stock cylinedrs and I have 35.5 PWK´s. 40-42 pilot and 152-155 mains, needle in the midle and 1.25-1.5 turns out. -Pasi S. Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted June 13, 2010 Author Report Share Posted June 13, 2010 I´m not an expert but... I think you are too rich on your jets. That´s why it won´t make any rpm´s. Clean up your filters and put in new spark plugs and it´s also a good thing to clean your carbs also. Then I would go a smaller size pilots and mains. I have ported stock cylinedrs and I have 35.5 PWK´s. 40-42 pilot and 152-155 mains, needle in the midle and 1.25-1.5 turns out. -Pasi S. What size pilots & mains you think I should buy to start with dailing my jetting in? Quote Link to comment Share on other sites More sharing options...
Rodneya Posted June 14, 2010 Report Share Posted June 14, 2010 Check the parking brake switch and wiring. It acts as a rev limiter. Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted June 14, 2010 Author Report Share Posted June 14, 2010 Check the parking brake switch and wiring. It acts as a rev limiter. I have a parking brake block off & the T.O.R.S removed. I think it's jetting, I just dont know which jets to start with. Quote Link to comment Share on other sites More sharing options...
bansheerage Posted June 14, 2010 Report Share Posted June 14, 2010 i am sea level with your mods you need a bigger main jet 152 is way to small. i have a similar setup and im running 280 mains. bike runs like a raped ape. 27.5 pilot also Quote Link to comment Share on other sites More sharing options...
pr0blumz Posted June 14, 2010 Report Share Posted June 14, 2010 i am sea level with your mods you need a bigger main jet 152 is way to small. i have a similar setup and im running 280 mains. bike runs like a raped ape. 27.5 pilot also He doesn't have stock carbs. Quote Link to comment Share on other sites More sharing options...
Rodneya Posted June 14, 2010 Report Share Posted June 14, 2010 I have a parking brake block off & the T.O.R.S removed. I think it's jetting, I just dont know which jets to start with. TORS and parking brake are totally different things. The block off is just a plate on the rear caliper. Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted June 14, 2010 Author Report Share Posted June 14, 2010 TORS and parking brake are totally different things. The block off is just a plate on the rear caliper. I agree thats why I said I have the parking break block off & TORS removed. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted June 14, 2010 Report Share Posted June 14, 2010 I agree thats why I said I have the parking break block off & TORS removed. What Rodneya is sayin is that the block off plate only goes on the caliper....he's inquiring as to whether you disconnected the wiring to the switch... Quote Link to comment Share on other sites More sharing options...
bansheerage Posted June 15, 2010 Report Share Posted June 15, 2010 is 152 a big main for a PJ Keihin? i dont run em so i dont know Quote Link to comment Share on other sites More sharing options...
Zeroskill Posted June 15, 2010 Report Share Posted June 15, 2010 is 152 a big main for a PJ Keihin? i dont run em so i dont know I have 172 mains in my 35 PWKs with VF3s, T5s, +4 timing and 21cc domes on ported stock cylinders at sea level. I don't know how PJs compare to PWKs though. Quote Link to comment Share on other sites More sharing options...
Erwin8r Posted June 15, 2010 Report Share Posted June 15, 2010 Check the parking brake switch and wiring. It acts as a rev limiter. I second this. Your jetting isn't that far off. But after you check your wiring, you need to yank your carbs and check your reeds (make sure there are no broken petals, etc.) and check your carb internals. PJ's (yours is either a 34 or a 36mm...) are very similar to PWk's in terms of jetting. Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted June 17, 2010 Author Report Share Posted June 17, 2010 I second this. Your jetting isn't that far off. But after you check your wiring, you need to yank your carbs and check your reeds (make sure there are no broken petals, etc.) and check your carb internals. PJ's (yours is either a 34 or a 36mm...) are very similar to PWk's in terms of jetting. I dont have the stock clutch perch with the parking brake wiring on it. I removed the TORS system completely. (clutch, throttle & carbs are not stock) The reeds are new but I will double check them. I know I need to adjust the float height on the right carb, cause gas be coming out of the drain hose a little. Thanks for any advice. All help is certainly appreciated. Quote Link to comment Share on other sites More sharing options...
