WannaBeeRider Posted June 13, 2010 Report Share Posted June 13, 2010 ok well im buying a banshee. and i had some durability questions about the shee's. are they good trail quads with just pipes bored over 1mm, port polish, +4 timing, stock carbs, t5 pipes? if i maintain my motor use klotz 32:1 racing mix, gearsaver 85W and a good foam filter will my motor last? will the tranny too? im in the market for a fast durable quad. im ether getting a z400 or a banshee. and if i go with the z400 i plan on rebuilding it maby once every 3 years? iv grow up around the 2-smokes. i have a trx250r right now and im parting her out cause its a pice of shit and all the bearings are shot. motors brand new tho lol./ also what are the best front shock;s that requier no mods for 450$ new? do banshees feel tipsy? any other tips for me? all help aprestiated Quote Link to comment Share on other sites More sharing options...
WannaBeeRider Posted June 13, 2010 Author Report Share Posted June 13, 2010 also anouther question. with those mods what hp am i at? Quote Link to comment Share on other sites More sharing options...
overrevtricky Posted June 13, 2010 Report Share Posted June 13, 2010 My setup below is a trail killer. Lots of times even overboard thanks to the head. When I was running with those mods minus the head it was awesome, but even in really tight stuff it can get shaky. Can't tell u what durability is like, as I just rebuilt, but I have seen alot of guys on here say 3-7 years on a top-end. Mine felt tipsy with the stock tires, threw some slightly wider Kenda Klaws on and that went away. -Banshees Rule! Quote Link to comment Share on other sites More sharing options...
madjimmax Posted June 13, 2010 Report Share Posted June 13, 2010 A banshee is like any other motor powered vehicle. If you start out with a sound machine and take care of it it will take care of you, on the other hand if you purchase some piece of shit that has bandaids all over the place you'll be wrenching more then riding. If you buy the 400 you'll be regretting it the first time you pull up beside a shee wanting to race. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted June 13, 2010 Report Share Posted June 13, 2010 ok well im buying a banshee. and i had some durability questions about the shee's. are they good trail quads with just pipes bored over 1mm, port polish, +4 timing, stock carbs, t5 pipes? if i maintain my motor use klotz 32:1 racing mix, gearsaver 85W and a good foam filter will my motor last? will the tranny too? im in the market for a fast durable quad. im ether getting a z400 or a banshee. and if i go with the z400 i plan on rebuilding it maby once every 3 years? iv grow up around the 2-smokes. i have a trx250r right now and im parting her out cause its a pice of shit and all the bearings are shot. motors brand new tho lol./ also what are the best front shock;s that requier no mods for 450$ new? do banshees feel tipsy? any other tips for me? all help aprestiated i actually own both a shee and a z400....they both have their ups and downs.. the shee has the wheel-lifting hard-pulling ass-puckering speed....absolutely AWSOME on a most wider trails. the z400 IS alot easier on the real tight technical trails though....and it is better on fuel. the shee will run down the z400 in a heartbeat... i love em both but the shee is more of a blast to ride...but if you ride LONG LONG distances your gonna need to carry oil or you wind up buying oil for a rediculous price and its usually not the same stuff you normally run...i actually built my own oil carrier that mounts inside the frame and carries enough to fill a full tank or measures out enough to fill by the gallon. all in all they are both good machines.....the shee will need a rebuild earlier as its a 2-stroke.....but they are WICKED easy to rebuild as apposed to the 4-strokers Quote Link to comment Share on other sites More sharing options...
midlifecrisis Posted June 14, 2010 Report Share Posted June 14, 2010 My buddies just rebuilding his 06 ltr 450 top end, and its costing him around $3000, maybe more, ask alf, hes supplied the parts, on the other hand, Im rebuilding my shee, and for the topend your looking at around $500, even if you do it every year, you do the math! Quote Link to comment Share on other sites More sharing options...
