87sheerips Posted June 10, 2010 Report Share Posted June 10, 2010 Well, getting ready for racing this weekend and I had to get some things done quick. I made up these struts from 1" aluminum bar stock (12.5 eye to eye all around) with 1/2" mounting holes Took the stock rubberized engine mounts, cut them apart, and welded on 1.125" bar stock with drilled holes for the bolts. I think it should keep the motor nice and secure. Powdercoated everything shuttle gloss black... If anyone would like some for themselves let me know Quote Link to comment Share on other sites More sharing options...
joee20002 Posted June 11, 2010 Report Share Posted June 11, 2010 Well, getting ready for racing this weekend and I had to get some things done quick. I made up these struts from 1" aluminum bar stock (12.5 eye to eye all around) with 1/2" mounting holes Took the stock rubberized engine mounts, cut them apart, and welded on 1.125" bar stock with drilled holes for the bolts. I think it should keep the motor nice and secure. Powdercoated everything shuttle gloss black... If anyone would like some for themselves let me know great job as always JD...... Quote Link to comment Share on other sites More sharing options...
87sheerips Posted June 11, 2010 Author Report Share Posted June 11, 2010 Thx brotha, these motor mounts are SOLID! Quote Link to comment Share on other sites More sharing options...
Koolguyson Posted June 11, 2010 Report Share Posted June 11, 2010 Thx brotha, these motor mounts are SOLID! On a small motor you may be fine. But on a bigger motor you want them to give a little. Otherwise sold mounting the bottom will break the threaded bosses off. Quote Link to comment Share on other sites More sharing options...
87sheerips Posted June 18, 2010 Author Report Share Posted June 18, 2010 On a small motor you may be fine. But on a bigger motor you want them to give a little. Otherwise sold mounting the bottom will break the threaded bosses off. So the bigger motors you would use rubber underside mounts with a stator cover side support? Either way these bottom mounts secured my motor great Quote Link to comment Share on other sites More sharing options...
