problem..need help..
i have a 95 banshee..i just put new pistons in it and also the oil seals. and now it is only running on one cylinder. and both cylinders are getting spark and fuel. wat could it be?
welcome to BHQ
switch your plugs and see if it changes to the other cyl. and clean the carbs
Edited by toytech
Synchronize the carbs (adjust cable to they open and close at the same time) and make sure the throttle cable is not in a bind anywhere. Make sure the choke tube is in place. Black hose that connects the carbs together.
welcome to my nightmare...im in the same situation...was running fine before the rebuild except psi difference..rebuilt it and did a few other mods and slapped it back together and it doesnt run right....right plug is super lean....ive tried everything...so im finally doing a leak down...i just buiilt my tester..i recommend you to do that. if you have an air leak then you will run super lean.
:lol:
