bansheemann420 Posted June 9, 2010 Report Share Posted June 9, 2010 ok i have a 02 banshee boysen reeds and k&n im having a reallly hard time gettin it to run right. it will not idle . and backfires coming off the sensor. it has no power after 3/4 throttle the carbs are in sync. no powerband when i get into 5ht and 6th it bogs out and i have to down shift. i dont understand whats goin wrong anyone with someknowledge Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted June 9, 2010 Report Share Posted June 9, 2010 ok i have a 02 banshee boysen reeds and k&n im having a reallly hard time gettin it to run right. it will not idle . and backfires coming off the sensor. it has no power after 3/4 throttle the carbs are in sync. no powerband when i get into 5ht and 6th it bogs out and i have to down shift. i dont understand whats goin wrong anyone with someknowledge Could be a number of things. 1) Have you re-jetted since the mods? 2) Check your pickup gap on the flywheel. Should be the thickness of a business card. .016 (someone correct me if I'm wrong) 3) If you have a friend with a shee, try and swap your coil to rule that one out. 4) Also, same thing as #3, try swapping out your CDI with a buddy. Quote Link to comment Share on other sites More sharing options...
hercalmighty Posted June 9, 2010 Report Share Posted June 9, 2010 What's your jetting? Do you have pipes? Quote Link to comment Share on other sites More sharing options...
bansheemann420 Posted June 10, 2010 Author Report Share Posted June 10, 2010 it was running fine about 3 months ago i didnt touch it for 2 and now its acting up. jetting is stock no pipes Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted June 10, 2010 Report Share Posted June 10, 2010 (edited) Clean the carbs, check plugs, clean air filter. Still have tors? Use fresh gas, all the good shit has probably evporated off.! Edited June 10, 2010 by Larry's Shee Quote Link to comment Share on other sites More sharing options...
bansheemann420 Posted June 10, 2010 Author Report Share Posted June 10, 2010 i still have tors dont really have money to spend on newcaps Quote Link to comment Share on other sites More sharing options...
hercalmighty Posted June 10, 2010 Report Share Posted June 10, 2010 Just unplug the control box for now. Quote Link to comment Share on other sites More sharing options...
firebanshee Posted June 10, 2010 Report Share Posted June 10, 2010 Put in NEW spark plugs. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted June 10, 2010 Report Share Posted June 10, 2010 jetting is stock no pipes If you have a k&n and reeds, you need to re-jet also. Quote Link to comment Share on other sites More sharing options...
bansheemann420 Posted June 10, 2010 Author Report Share Posted June 10, 2010 If you have a k&n and reeds, you need to re-jet also. what should i run a 230 main and 25 pilot Quote Link to comment Share on other sites More sharing options...
fastquad02blaster Posted June 11, 2010 Report Share Posted June 11, 2010 As for it not running right but it used to, clean the carbs. For the jetting you just need to play with it and get it right for your bike. Start big and come down. Quote Link to comment Share on other sites More sharing options...
madjimmax Posted June 12, 2010 Report Share Posted June 12, 2010 what should i run a 230 main and 25 pilot I would probably start with a 250 and check it out its always better to start out too rich then too lean. And as far as the 25 pilot that would be fine until you get some pipes and then you would need a 27.5. As soon as you can afford to you need to get rid of the TORS that shit can be more problems then they're worth. Quote Link to comment Share on other sites More sharing options...
bansheemann420 Posted June 12, 2010 Author Report Share Posted June 12, 2010 I would probably start with a 250 and check it out its always better to start out too rich then too lean. And as far as the 25 pilot that would be fine until you get some pipes and then you would need a 27.5. As soon as you can afford to you need to get rid of the TORS that shit can be more problems then they're worth. i just disconnected the control box. one of the tors wires from the right carb shorted out against the exhaust. im thinking thats why it was backfiring Quote Link to comment Share on other sites More sharing options...
madjimmax Posted June 13, 2010 Report Share Posted June 13, 2010 i just disconnected the control box. one of the tors wires from the right carb shorted out against the exhaust. im thinking thats why it was backfiring Good chance thats it. Did you unhook it and try to run it? Quote Link to comment Share on other sites More sharing options...
