Jaystre Posted June 4, 2010 Report Share Posted June 4, 2010 just want to know if anyone ever tried to unkink a pipe by putting water in it and leaving it in the cooler over night ... ? Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted June 4, 2010 Report Share Posted June 4, 2010 I've heard of this. I'if it's a big kink chances are it'll take more than just that. PM AKheathen about his air compresser method. Seems like it would work good for a bad kink Quote Link to comment Share on other sites More sharing options...
AKheathen Posted June 6, 2010 Report Share Posted June 6, 2010 if it's a bent pipe, then there is allot more than just poppin dents out. probably, have to cut, reshape, then weld back Quote Link to comment Share on other sites More sharing options...
Jaystre Posted June 6, 2010 Author Report Share Posted June 6, 2010 if it's a bent pipe, then there is allot more than just poppin dents out. probably, have to cut, reshape, then weld back yeah its a pretty good kink but didnt seem to affect performance at all Quote Link to comment Share on other sites More sharing options...
Erwin8r Posted June 6, 2010 Report Share Posted June 6, 2010 I've done it with 4-poke pipes (on my KX450 ti Pro circuit header, for example) with good results. The ti header was easy. A thicker, stainless header took a couple tries to get the dent fully out. I'd try it, at least. Quote Link to comment Share on other sites More sharing options...
chetgoff Posted June 6, 2010 Report Share Posted June 6, 2010 My brother-n-law did this with his stock cr-250 pipe and it split open and blew black soot all over his freezer. His wife was pissed. it will work with aftermarket pipes that are welded together but i would not do with stock pipes Quote Link to comment Share on other sites More sharing options...
firebanshee Posted June 6, 2010 Report Share Posted June 6, 2010 My brother-n-law did this with his stock cr-250 pipe and it split open and blew black soot all over his freezer. His wife was pissed. it will work with aftermarket pipes that are welded together but i would not do with stock pipes That's funny,my wife is always getting mad at me for doing shit like that Quote Link to comment Share on other sites More sharing options...
Jaystre Posted June 6, 2010 Author Report Share Posted June 6, 2010 ill give it a try and let u know what hapenned Quote Link to comment Share on other sites More sharing options...
Building my First Posted June 8, 2010 Report Share Posted June 8, 2010 Here is a goo thread. A little psi and a propane torch. http://forums.everything2stroke.com/showthread.php?t=35571&highlight=torch+pipes Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 9, 2010 Report Share Posted June 9, 2010 Risk isn't worth the reward when it comes to fixing pipes. Pacific Crest Pipe Repair are the masters. http://www.piperepair.com/ Quote Link to comment Share on other sites More sharing options...
