ionroller Posted June 5, 2010 Author Report Share Posted June 5, 2010 on my new clutch kit should I go 3 HD and 3 stock springs? I only have fattys and a pro flow Quote Link to comment Share on other sites More sharing options...
TNTS355 Posted June 5, 2010 Report Share Posted June 5, 2010 on my new clutch kit should I go 3 HD and 3 stock springs? I only have fattys and a pro flow that would be good. make sure you torque the clutch bolts correctly, you will snap them if you tighten them to much Quote Link to comment Share on other sites More sharing options...
camatv Posted June 5, 2010 Report Share Posted June 5, 2010 if its an all original 87 i'd say it needs a clutch. best way to fix it is replace it. the type f trans fluid breaks down very fast i'd use any other motorcycle specific oil in the bottom end besides that crap. get a manual or look online for adjusting it thats very cucial to these bikes. the tusk clutch works great lube your clutch cable and install all the springs that come with it ( if you buy the one including springs hopefully you did) the springs in that kit arent much stiffer than stock and with a lubed cable and proper adjustment shouldnt pull any harder.. Quote Link to comment Share on other sites More sharing options...
camatv Posted June 5, 2010 Report Share Posted June 5, 2010 once the clutch is in you can get one of these to feel the new found power http://kalecoauto.com/index.php?main_page=product_info&cPath=7&products_id=41 Quote Link to comment Share on other sites More sharing options...
