ionroller Posted June 3, 2010 Report Share Posted June 3, 2010 I have a 87 that is almost stock and the clutch has started to slip, will a $50 ebay kit work good? and can i do it through the cover or do i have to take the whole side pannel off? Or is it possible to adjust it, It has been slipping for a couple days now. Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted June 3, 2010 Report Share Posted June 3, 2010 Chances are, the clutch is toasted, if it's been slipping for several days. You'll have to remove the whole side cover to change the clutch, and you'll need a new clutch cover gasket. What brand is the eGay clutch? Quote Link to comment Share on other sites More sharing options...
ionroller Posted June 3, 2010 Author Report Share Posted June 3, 2010 some are tusk and some dont say Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted June 3, 2010 Report Share Posted June 3, 2010 Yeah, check your adjustment first before you plunk down $$. Have you changed trans fluid lately? Quote Link to comment Share on other sites More sharing options...
ionroller Posted June 3, 2010 Author Report Share Posted June 3, 2010 yes, just changed it and re jetted and started to notice it. I used ams oil i think 0w 40 Quote Link to comment Share on other sites More sharing options...
T_Shee Posted June 3, 2010 Report Share Posted June 3, 2010 does your perch have some free play to it? if there is no free play then you prollly just need adjustment. make sure you can pull in on the lever a half inch or so before you feel resistance. tusk is a pretty good clutch i wouldnt hesitate to run one unless its a higher power motor Quote Link to comment Share on other sites More sharing options...
ionroller Posted June 3, 2010 Author Report Share Posted June 3, 2010 yes there is plenty of play.. could it be the oil? And is the clutch garbage now that it has been slipping? Quote Link to comment Share on other sites More sharing options...
NickisGod Posted June 3, 2010 Report Share Posted June 3, 2010 Go into the image section and find my post called clutch cover devistaion. That's what happen when I was experiancing clutch slippage. Quote Link to comment Share on other sites More sharing options...
ionroller Posted June 3, 2010 Author Report Share Posted June 3, 2010 SHOULD I ADJUST OR JUST GO FOR A KIT Quote Link to comment Share on other sites More sharing options...
ionroller Posted June 3, 2010 Author Report Share Posted June 3, 2010 Ok I just bought a clutch kit and a gasket!! Is there anything special i will need, and also will I need to drain the coolant? Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted June 3, 2010 Report Share Posted June 3, 2010 What oil are u running? I have always used tusk HD kits in all my bikes. Right now I just run three stock springs and three hd springs. Make sure u soak the clutches over night before install Quote Link to comment Share on other sites More sharing options...
ionroller Posted June 4, 2010 Author Report Share Posted June 4, 2010 What oil are u running? I have always used tusk HD kits in all my bikes. Right now I just run three stock springs and three hd springs. Make sure u soak the clutches over night before install Its ams oil 4 cycle oil. says its good for wet clutches Quote Link to comment Share on other sites More sharing options...
TNTS355 Posted June 4, 2010 Report Share Posted June 4, 2010 make sure you read your Clymers on how to adjust the clutch before putting on the cover. If you dont you will have to take the cover off again and adjust it. if you are new to working on banshee's, nitronate has a good video for working on shee's. Quote Link to comment Share on other sites More sharing options...
toytech Posted June 4, 2010 Report Share Posted June 4, 2010 Its ams oil 4 cycle oil. says its good for wet clutches vitos sells a clutch that works great for 69 bucks Quote Link to comment Share on other sites More sharing options...
toytech Posted June 4, 2010 Report Share Posted June 4, 2010 i would say check the oil. if it started slipping are the oil change then that might be the cause. should have used ATF. some oils have friction modifiers in them and they are not good for a clutch. he used the amsoil 4 stroke oil for wet clutches should be ok, I've used that with no problem Quote Link to comment Share on other sites More sharing options...
