blaster sprocket hub on banshee?
Will a sprocket hub off of a blaster fit my banshee axle? I need one by sunday and i found a blaster one locally for dirt cheap....thanks
Im not 100% sure but i think they do fit. They have the same hole patter as the warrior blaster and banshee.
Im sure someone will pop in here to confirm.
It will fit the axle but not a banshee rim. It has s different bolt pattern.
he's asking about the hub the sprocket bolts directly on to, not the hub the rim goes on. You probably read it real fast and weren't paying attention
