Jaystre Posted May 25, 2010 Report Share Posted May 25, 2010 can u get more traction by upgrading the shocks my shee just seems to spin the tires all the time and there almost brand new Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted May 25, 2010 Report Share Posted May 25, 2010 sounds like you need to learn to throw your weight around on the bike. or feather the throttle rather then just pin and go. But having a well built shock for your style of riding will always help keep the wheels to the ground while the bike stay flatter better. But more then likely, your rear shocks is in well need for a rebuild. The stock fronts just blow donkey. Quote Link to comment Share on other sites More sharing options...
someone82 Posted May 25, 2010 Report Share Posted May 25, 2010 can u get more traction by upgrading the shocks my shee just seems to spin the tires all the time and there almost brand new What do you run for air pressure? Quote Link to comment Share on other sites More sharing options...
banshitty Posted May 27, 2010 Report Share Posted May 27, 2010 sounds like you need to learn to throw your weight around on the bike. or feather the throttle rather then just pin and go. But having a well built shock for your style of riding will always help keep the wheels to the ground while the bike stay flatter better. But more then likely, your rear shocks is in well need for a rebuild. The stock fronts just blow donkey. [/quote Try running tire pressure @ 2.5 to 3 p.s.i and stiffen up the preload on rear shock. Quote Link to comment Share on other sites More sharing options...
